Hi there
anyone knows if I can set a tag to a existing backup? I need to identify different backups as we changed our database format, but I forgot to do it while copying the backup. Is it possible to do it after?
Thanks
Emilio
Hi there
Thanks
Emilio
Sorry, you can’t add a tag after a backup has finished. The only way to specify the tag to pass it to the backup command.
