SFTP or WebDav?
Hi there,
my backup target supports both protocols.
Is there a recommendation which protocol to use with duplicacy?
Are there advantages/disadvantages from one to the other in terms of duplicacy?
Thanks, Alex
I would go with SFTP, which is preinstalled on most linux systems. WebDav on the other hand, doesn’t have a well-defined specification and there may be compatibility issues between different implementations.
I fiddled a lot with WebDAV and Duplicacy. Suffice to say, I ended up using S3.
