Hi everybody,
I “suddenly” have a problem with my off-site-backup to Strato HiDrive. It was working once and now it doesn’t anymore - not sure when it started, I just found out about it and my logs say it’s happening since at least a month…
My setup:
Latest Duplicacy Docker Container v1.8.3 (https://hub.docker.com/r/saspus/duplicacy-web/) on unRAID v6.12.2 with duplicacy-cli manually updated to v3.2.4 (after unsucessfully trying the shipped v3.2.3)
I have 2 storage destinations configured: One remote to Strato HiDrive and one local to another NAS (Synology DS412+), both using SFTP with the same keyfile for authenticating both.
The local backups (sftp to synology) work just fine.
When trying to start a remote backup, I get the following error:
Running backup command from /cache/localhost/7 to back up /backuproot/foo
Options: [-log -d -v backup -storage hidrive -threads 4 -stats]
2024-12-10 08:11:21.466 INFO REPOSITORY_SET Repository set to /backuproot/foo
2024-12-10 08:11:21.466 INFO STORAGE_SET Storage set to sftp://redacted@sftp.hidrive.strato.com//users/redacted/backup
2024-12-10 08:11:21.466 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_HIDRIVE_SSH_KEY_FILE
2024-12-10 08:11:21.671 DEBUG SSH_PUBLICKEY Attempting public key authentication
2024-12-10 08:11:21.671 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_HIDRIVE_SSH_KEY_FILE
2024-12-10 08:11:21.685 DEBUG SSH_PASSWORD Attempting password login
2024-12-10 08:11:21.685 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_HIDRIVE_SSH_PASSWORD
2024-12-10 08:11:21.685 DEBUG KEYRING_GET Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: exec: "dbus-launch": executable file not found in $PATH
Enter SSH password:2024-12-10 08:11:21.685 ERROR PASSWORD_READ Failed to read the password: EOF
exit status 100
When using the “normal” sftp command inside the duplicacy docker container with the same keyfile as configured in duplicacy-web, I can connect to HiDrive just fine.
When trying to add a new storage destination for HiDrive inside duplicacy-web, I get a similar error when trying to select the destination folder:
Failed to create the sftp client: ssh: handshake failed: ssh: unable to authenticate, attempted methods [none publickey], no supported methods remain
I’ve tried setting the DUPLICACY_HIDRIVE_SSH_KEY_FILE environment variable manually (using the -e parameter with Docker), re-setting the encryption key in the duplicacy-web settings and manually connecting with sftp on the cli to accept the hostkey first.
It looks very similar to this old problem to me but I have no Idea how to check if there are any declined ciphers being negotiated nor what ciphers are okay with HiDrive:
Any help is very much appreciated and if you need any more info just tell me - I’m happy to provide!
Thanks in advance,
Philipp
