With my nightly backup since a week when performing prune operation I got signal killed.
See logs:
Running prune command from /root/.duplicacy-web/repositories/localhost/all
Options: [-log prune -storage backup -keep 0:1800 -keep 7:30 -keep 1:7 -a]
2020-10-05 00:02:42.164 INFO STORAGE_SET Storage set to /mnt/backup
2020-10-05 00:02:42.168 INFO RETENTION_POLICY Keep no snapshots older than 1800 days
2020-10-05 00:02:42.168 INFO RETENTION_POLICY Keep 1 snapshot every 7 day(s) if older than 30 day(s)
2020-10-05 00:02:42.168 INFO RETENTION_POLICY Keep 1 snapshot every 1 day(s) if older than 7 day(s)
2020-10-05 00:02:44.196 INFO SNAPSHOT_DELETE Deleting snapshot doktorantske at revision 100
2020-10-05 00:02:44.231 INFO SNAPSHOT_DELETE Deleting snapshot doktorantske at revision 101
2020-10-05 00:02:44.249 INFO SNAPSHOT_DELETE Deleting snapshot documents at revision 91
2020-10-05 00:02:44.262 INFO SNAPSHOT_DELETE Deleting snapshot documents at revision 92
2020-10-05 00:02:44.269 INFO SNAPSHOT_DELETE Deleting snapshot mp3 at revision 85
2020-10-05 00:02:44.740 INFO SNAPSHOT_DELETE Deleting snapshot mp3 at revision 86
2020-10-05 00:02:45.136 INFO SNAPSHOT_DELETE Deleting snapshot pictures at revision 86
2020-10-05 00:02:49.496 INFO SNAPSHOT_DELETE Deleting snapshot pictures at revision 87
2020-10-05 00:02:53.739 INFO SNAPSHOT_DELETE Deleting snapshot projects-install at revision 61
2020-10-05 00:02:54.503 INFO SNAPSHOT_DELETE Deleting snapshot projects-install at revision 62
2020-10-05 00:02:55.023 INFO SNAPSHOT_DELETE Deleting snapshot videocutwork at revision 81
2020-10-05 00:03:03.105 INFO SNAPSHOT_DELETE Deleting snapshot videocutwork at revision 82
2020-10-05 00:03:10.762 INFO SNAPSHOT_DELETE Deleting snapshot work at revision 85
2020-10-05 00:03:11.406 INFO SNAPSHOT_DELETE Deleting snapshot work at revision 86
signal: killed
It should prune my old backups. Same happens when executing check.
The execution of duplicacy is stopped.
Version: Duplicacy Web Edition 1.3.0
