Hi is it possible to have Duplicacity send emails without requiring SMTP authentication? Our SMTP server authenticates based on IP address. I don’t wish to enter a user name/password.
Currently not supported, but I’ll consider this after the mutlithreading support and the B2 3xxx status code fix.
Hi I was wondering if this feature was available yet or if it is planned?
Sorry I forgot about this. What is the OS that you intend to run Duplicacy on? I can get you a special pre-2.0.10 build.
Actually if you just manually edit the .duplicacy/schedule file under the repository to set an empty username, like:
"username" : ""
It should work with the current version.
In the next version I’ll enable the ‘Save’ and ‘Test’ buttons if the username field is blank.
