I am using the Duplicacy v0.2.1 Linux ARM web ui to back up data to Wasabi. Web ui shows 1 Storages, 2 Backups, and 2 schedules. I just watched Duplicacy spend 3 days uploading 170 GB to Wasabi. I am using default settings or have not changed anything except for options to be -threads 4.
Storage tab reports Size 0, Backup IDs 0, Chunks 0, Status Checked. And, “All reference chunks exist.”
Backup tab reports 2 IDs with their associated Directory, Storage, and Include/Exclude.
Schedule lists the backup as “Completed” and a job Check as “Checked”.
Restore reports accurate storage. Backup IDs is “No Backups found on this storage”. Revision is greyed out; Restore To and Options are blank.
Seems Duplicacy backed up 170GB, as reported on Wasabi, but does not see its own backup. Is there a way to get it to see its own backup and restore files when it doesn’t let me select any Backup IDs and they are clearly on Wasabi?
