I try to exclude directories named
.Recycle.Bin
via the syntax
-.Recycle.Bin/
But it still included. Does that . need same kind of escape character?
Thanks
.Recycle.Bin
via the syntax
-.Recycle.Bin/
Thanks
I don’t think dot is treated any differently than any other character. Only star and question mark have special meaning.
This
-.Recycle.Bin/
will only exclude this folder in the root of the repository. Is that the intention? Which OS is it on?
Thanks for the quick hint. Its the root of the share but not of the repository
Solved, thanks a million.
