Hi
Per my understanding with the Backblaze B2 Cloud storage is not possible to use a specific path in a bucket as the storage, but the entire bucket is used.
Is this correct?
Hi
Is this correct?
Yes, this is correct.
But, if you wish, you can point the backup of two or more repositories to the same bucket. The different backups will be identified by the snapshot-ids.
If these repositories have similar files, you will benefit from deduplication.
These different backups will share the same encryption configuration, if used, as the config file will be unique in the storage / bucket
I personally prefer to have a separate bucket for each backup, itβs easier to manage space, etc.
Itβs clear now
