Hello all,
I have a setup that uses SFTP for local network backups, and I recently changed the server to limit the number of failed authentication attempts. The SFTP storage uses an ssh key for authentication, but I believe I’ve found an issue where the key specified for the storage is ignored and the keys stored by ssh-agent are used. This is on MacOS 11.2.1 using licensed duplicacy-web rather than just the CLI version.
When setting up a new storage backend, I specified the host name, the user name, the key file to use, and then click the folder icon to browse for the storage location. This works! I can choose the folder on the remote server perfectly fine. But when continuing to the next configuration page, I get an authentication error. Clearly there are two code paths for authentication here, which I believe is a bug or at the least unexpected.
To prove this theory, I placed my SSH server into debug logging level and captured several key authentication attempts failing, which should not be happening. I have specifically provided a key to be used, no other key should ever be attempted! The error was obvious once I looked at the logs themselves, because the key I use for duplicacy is an ED25519 key, but the logs mention several RSA keys which are used for legacy systems I have access to. Here is a snippet from those logs.
Jun 21 16:30:01 rhodes sshd[735954]: Connection from 192.168.1.73 port 53159 on 192.168.1.21 port 22 rdomain ""
Jun 21 16:30:01 rhodes sshd[735954]: debug1: userauth-request for user duplicacy-user service ssh-connection method none [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: attempt 0 failures 0 [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: user duplicacy-user matched 'User duplicacy-user' at line 1
Jun 21 16:30:01 rhodes sshd[735954]: debug1: userauth-request for user duplicacy-user service ssh-connection method publickey [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: attempt 1 failures 0 [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: userauth_pubkey: test pkalg ssh-rsa pkblob RSA SHA256:zj9Wx033fSaQTZ/PaLo3kXLs3YFePJ7HwZwAq9RUdms [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: temporarily_use_uid: 1001/1001 (e=0/0)
Jun 21 16:30:01 rhodes sshd[735954]: debug1: trying public key file /home/duplicacy/.ssh/authorized_keys
Jun 21 16:30:01 rhodes sshd[735954]: Failed publickey for duplicacy-user from 192.168.1.73 port 53159 ssh2: RSA SHA256:zj9Wx033fSaQTZ/PaLo3kXLs3YFePJ7HwZwAq9RUdms
[SNIP] Repeats for 3 more keys
Jun 21 16:30:01 rhodes sshd[735954]: debug1: attempt 5 failures 4 [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: userauth_pubkey: test pkalg ssh-ed25519 pkblob ED25519 SHA256:HWJIsLtXgeof4hkJqDigRbKFqJibM9KRWCgKBkN2Y3Q [preauth]
Jun 21 16:30:01 rhodes sshd[735954]: debug1: fd 5 clearing O_NONBLOCK
Jun 21 16:30:01 rhodes sshd[735954]: debug1: /home/duplicacy/.ssh/authorized_keys:1: matching key found: ED25519 SHA256:HWJIsLtXgeof4hkJqDigRbKFqJibM9KRWCgKBkN2Y3Q
Jun 21 16:30:01 rhodes sshd[735954]: debug1: /home/duplicacy/.ssh/authorized_keys:1: key options: agent-forwarding port-forwarding pty user-rc x11-forwarding
Jun 21 16:30:01 rhodes sshd[735954]: Accepted key ED25519 SHA256:HWJIsLtXgeof4hkJqDigRbKFqJibM9KRWCgKBkN2Y3Q found at /home/duplicacy/.ssh/authorized_keys:1
The expected behavior here is that when I specify a key file in the storage configuration, that key and only that key will be used for authentication. Using other keys stored in the ssh-agent is, at a minimum, very confusing and at its worst a security concern (though not likely a vulnerability since the user must have the keys added to their agent, and the username on the remote host must exist).
It’s completely possible that I’m missing some critical detail here, but I know when I configure my ssh client to use a specific key for a host configuration, that key and only that key are used. I would have expected the same behavior from duplicacy, perhaps incorrectly. Any help here would be great, since I absolutely want to get my maximum auth attempts back down to something sensible.
