I have changed the machine so the ssh key is now different. I removed the storage and tried to add it again but it won’t let me due to the ssh key mismatch.
How do I tell it to accept the new key in the webui?
Delete the known_hosts file (or old host ID from that file).
Edit. Ah wait. Are you saying hostid changed or you generated a new key for authentication?
host id (key fingerprint) changed.
Yeah, delete known_hosts file.
Where is the file? It’s not in ~/.ssh/
Somewhere under ~/.duplicacy_web/repositories
Or if you using my container — under /caches
I’m afraid neither directory exists. I’m using your container:
/ # ls -la
total 20
drwxr-xr-x 1 root root 198 Jan 17 16:46 .
drwxr-xr-x 1 root root 198 Jan 17 16:46 ..
-rwxr-xr-x 1 root root 0 Jan 17 16:46 .dockerenv
drwxrwxrwx 1 duplicac duplicac 4096 Jan 15 16:25 backuproot
drwxr-xr-x 1 root root 870 Sep 23 04:11 bin
drwxrwxrwx 1 duplicac duplicac 23 Jan 9 23:08 cache
drwxrwxrwx 1 duplicac duplicac 220 Jan 17 17:17 config
drwxr-xr-x 5 root root 340 Jan 17 16:46 dev
drwxr-xr-x 1 root root 776 Jan 17 16:46 etc
drwxr-xr-x 1 root root 18 Jan 17 16:46 home
drwxr-xr-x 1 root root 282 Aug 7 14:09 lib
drwxrwxrwx 1 duplicac duplicac 12288 Jan 17 17:17 logs
drwxr-xr-x 1 root root 28 Aug 7 14:09 media
drwxr-xr-x 1 root root 0 Aug 7 14:09 mnt
drwxr-xr-x 1 root root 0 Aug 7 14:09 opt
dr-xr-xr-x 1065 root root 0 Jan 17 16:46 proc
drwxrwxrwt 7 duplicac duplicac 140 Jan 12 15:40 remotes
drwx------ 1 root root 24 Jan 17 16:46 root
drwxr-xr-x 1 root root 0 Aug 7 14:09 run
drwxr-xr-x 1 root root 804 Sep 23 04:11 sbin
drwxr-xr-x 1 root root 0 Aug 7 14:09 srv
dr-xr-xr-x 13 root root 0 Jan 17 16:46 sys
drwxrwxrwt 1 root root 0 Aug 7 14:09 tmp
drwxr-xr-x 1 root root 54 Sep 23 04:11 usr
drwxr-xr-x 1 root root 86 Aug 7 14:09 var
/ # ls -la cache
total 0
drwxrwxrwx 1 duplicac duplicac 23 Jan 9 23:08 .
drwx------ 1 duplicac duplicac 193 Jan 17 17:16 localhost
find /cache -name known_hosts
okay so there’s tons of known_hosts under /cache/localhost/[n]/.duplicacy/known_hosts
how do I know which ones to delete?
Delete all of them
find /cache -name known_hosts -delete
Edit. Or you can look into each file and delete the lines corresponding to the hostname of your server. But why bother.
