OneDrive itself shows the size of my storage is 670G. Web UI shows 709.97G. Any ideas why such a big difference?
Hehe, as long as onedrive shows less, i think you’re safe!
(could this be relate to Giga Bytes and Gibi Bytes?)
I’m having the same “issue” with pCloud (via webdav): Duplicacy says I’m using 3.85 TB but pCloud says it’s only 3.53 TB:
The difference between the numbers is actually even bigger, considering that I also have some non-dupliacy data in that storage.
@gchen, do you have any explanation?
How did you get 4Tb of space on pcloud? I thought their plans top out at 2Tb? I could do with additional space myself.
PM me if needed
I trust Duplicacy’s number more than pcloud’s
Can you find a way to list all files and count the total size?
+1 for anything ndcu!
