I running a schedule including check. After completion click on ‘Storage’. Stats are ‘0’. This is inconsistent however and does not happen every time, or in a consistent manner.
Please note that check completes successfully.
I expect the statistics to be displayed correctly.
At the moment, statistics are 0 (see screenshots)
check completed successfully.
issue is somewhat similar to Dashboard, Storage status incorrect after check failed "Missing Chunks", but in my case the check does not report missing chunks.
