So I’ve newly installed duplicacy and backed up a test folder from unraid Server A to unraid Server B (using a SFTP app on Server B)
Now I’ve deleted one random blocks on Server B. Restore worked, as I did 5:1 redundancy. However once I deleted more blocks it didnt work. Well that is to be expected.
However, I ran a “check” command both times. Both times, the command itself said “Missing Chunks” in the status, but the Storage Tab never alerted me about this. It still says:
“Status: Checked - All referenced chunks exist”
Is this normal?
Also another quick question: Can I set the backup root where it backups the files from to read-only?
Update: It seems the Storage Tab doesnt update at all. After adding a new folder to be backed up it still says that there is 1 Backup ID total on Server B
