I’m able to upload chunks for around ten minutes before Storj errors out. Here is the end of my last job:
2023-04-03 21:14:33.667 INFO COPY_PROGRESS Copied chunk 5b57c9db6a9a2d92565a27f8ee56ac49572b2121bf2a6e6d908e4ecfe4a91ff1 (92/201819) 744KB/s 17 days 06:59:16 0.0%
2023-04-03 21:14:59.934 INFO COPY_PROGRESS Copied chunk 37fd3b26086fe8fc88fa8cad2ace13ab1ca36a3f4f0b20b7b02a066d7fa99b3a (95/201819) 723KB/s 17 days 09:22:11 0.0%
2023-04-03 21:15:06.555 ERROR UPLOAD_CHUNK Failed to upload the chunk 7eb2de813172e43f4c2519b3a94cff012c5eee6df7dde38522bcaf81c5d97747: uplink: stream: ecclient: successful puts (79) less than success threshold (80), ecclient: failed to dial (node:1WpsAmTYe5JFgED96mQUAErzscfxgRErk4WvrAyHkq8gjvXVBE): piecestore: rpc: tcp connector failed: rpc: dial tcp 51.161.91.140:28967: connect: connection refused; ecclient: failed to dial (node:12AfW4ZSUWVxjT8LU3hHxuSdDqyN4dSWwgVFyFmdnyAAHEudqrm): piecestore: rpc: tcp connector failed: rpc: dial tcp 213.32.245.249:28967: connect: no route to host; ecclient: upload failed (node:12MobUf67Ba4xhDt1bf4nBHvd3C76wEEgMdyB5kuzrTDZyGpnNc, address:95.217.12.194:28967): protocol: storage node overloaded, request limit: 32; ecclient: failed to dial (node:1UkpNUXB4vjRq9uNNeJQSyWZ8h4BJQ1deqwRVC1QWGiMtUGKKg): piecestore: rpc: tcp connector failed: rpc: dial tcp 46.29.162.156:29025: i/o timeout; ecclient: failed to dial (node:12bfHvpvZBi4HRmTh8YrNC5n2x9mYLaFYcNRcs8JrAsYJdopEtt): piecestore: rpc: tcp connector failed: rpc: dial tcp 45.129.2.46:29191: i/o timeout; ecclient: failed to dial (node:12PyFgAib2JdVAiCFeiwaz5vufJYDqRkStwzkqiqeYP2nY1JYyv): piecestore: rpc: tcp connector failed: rpc: dial tcp 46.241.125.18:28006: i/o timeout; ecclient: failed to dial (node:1KQs8vP9vbZL4VqDx98e7Qfdu5KJdmuMso4FSpkVrbMCEzvV7p): piecestore: rpc: tcp connector failed: rpc: dial tcp 37.220.82.246:28967: i/o timeout; ecclient: failed to dial (node:182WzkWv4xAb9grXVXDAfTwpHopk2cYZxZHQWqLXeYTPYZV3gJ): piecestore: rpc: tcp connector failed: rpc: dial tcp 185.117.154.118:28978: i/o timeout; ecclient: failed to dial (node:1DqhJBvU4WgYJgRyd5BXBrBY8oc9tk1gTqoB6PRHFRdfVYADfS): piecestore: rpc: tcp connector failed: rpc: dial tcp 45.8.98.152:29003: i/o timeout; ecclient: failed to dial (node:158kyhGAeic1szq5cWfeGDdtGScpzqGMPkrZTxmVJNJqHX7z5t): piecestore: rpc: tcp connector failed: rpc: dial tcp 193.109.79.135:28976: i/o timeout; ecclient: failed to dial (node:1cgYyDQ98ssRCRF8UJp1pvzghUZvV9JZZqjkKPYxfugVtCQxJp): piecestore: rpc: tcp connector failed: rpc: dial tcp 80.85.158.88:28978: i/o timeout; ecclient: failed to dial (node:1mT6ENWRZWbuYDLQrW5LfQqfiMf8AdjnwQVzA94diK8XyVigsX): piecestore: rpc: tcp connector failed: rpc: dial tcp 91.210.169.205:29106: i/o timeout; ecclient: failed to dial (node:129Hd51wiK3hDAF73tbqdV8gX7SsUWBr6hmUhzsUgUAZWeh8PUw): piecestore: rpc: tcp connector failed: rpc: dial tcp 185.31.163.23:40024: i/o timeout; ecclient: failed to dial (node:1kjQBzqfBm9dTui18LYm2tKBzZXhmDMqezvrqT1mSnJ7ENF9HU): piecestore: rpc: tcp connector failed: rpc: dial tcp 176.114.226.178:28967: i/o timeout; ecclient: failed to dial (node:12HYeHdE1K7UyoHNybBi3aV9Xyedyd5P5MXjFm1RWynQfVGY4eB): piecestore: rpc: tcp connector failed: rpc: dial tcp 87.237.47.211:28999: i/o timeout; ecclient: failed to dial (node:18A6EpBwJV2caLH7Z9QQCXgfizj3JFtvNEck6a5QNSho1EVEeJ): piecestore: rpc: tcp connector failed: rpc: dial tcp 178.250.157.154:40013: i/o timeout; ecclient: failed to dial (node:1FFFX4MHQKCUNaBuuEVc5Fyhe9qz2urcf8JzzrTan1VGCK2GbZ): piecestore: rpc: tcp connector failed: rpc: context deadline exceeded; ecclient: failed to dial (node:12iAtWvEZu1hMxRNcZaRYyqa4DrPTkQM34QtNzdYTKThbHNcM8A): piecestore: rpc: tcp connector failed: rpc: dial tcp 83.146.80.235:28967: i/o timeout; ecclient: failed to dial (node:122d78cfjZi6FoGwc2F9e4gcHYEHYMadtqYVmiX8TewLwTndCXJ): piecestore: rpc: tcp connector failed: rpc: dial tcp 62.109.26.14:28933: i/o timeout; ecclient: failed to dial (node:1ZqXsX4sfHHvaTxVyMHQcNwxi53erMBc6AThjtkMeA1UcnqSqd): piecestore: rpc: tcp connector failed: rpc: dial tcp 194.67.112.241:28936: i/o timeout; ecclient: failed to dial (node:12NVf9AvqBgDeKxSyJsoCpVKJrB5RYSg9NaVF9YAymkHumYe35q): piecestore: rpc: tcp connector failed: rpc: dial tcp 185.231.204.16:10141: i/o timeout; ecclient: failed to dial (node:1B24qCgo1TnMcwemqLgfJzQL7htKra2ZuQss6wXYgNGMdH69KL): piecestore: rpc: tcp connector failed: rpc: dial tcp 193.124.118.14:29132: i/o timeout; ecclient: failed to dial (node:12rfnjtzu4opGcrh85fb1nk36ff2yqFv9CpT4vxUxvf7ZpT4VAz): piecestore: rpc: tcp connector failed: rpc: dial tcp 81.200.144.227:29098: i/o timeout; ecclient: failed to dial (node:1kJK3vr1zjPCG7R6KyGimD3tb1DpdMzqXruCvYQotdfBU6Reb6): piecestore: rpc: tcp connector failed: rpc: dial tcp 194.87.210.83:29145: i/o timeout; ecclient: failed to dial (node:12MkEbqLJLpAMesAYmxtvic2WGzBR9niP5PuX6A2pVfC6t1SJeL): piecestore: rpc: tcp connector failed: rpc: dial tcp 95.165.14.7:28968: i/o timeout; ecclient: failed to dial (node:136eoyJWgDe1zkCT9TAzJiM4XyDg3C3ftiVKXrsR8c5PwCSo8k): piecestore: rpc: tcp connector failed: rpc: dial tcp 46.173.219.61:29118: i/o timeout; ecclient: failed to dial (node:1AVWugA48fnSnpLbEFRV5VPdEqZ7AaRvuPbszP3uTweuSqS1ST): piecestore: rpc: tcp connector failed: rpc: dial tcp 89.207.223.226:29245: i/o timeout; ecclient: failed to dial (node:12hNxck1huvWwg6SF6XJzq9KMp9zSWzButxTBz4pXRJeUQqdPBq): piecestore: rpc: tcp connector failed: rpc: dial tcp 83.217.5.100:29109: i/o timeout; ecclient: failed to dial (node:1AeqdQz11juwvKevB4BDpt4vLqMETY6ee9L7oR3edDkzYBgSbP): piecestore: rpc: tcp connector failed: rpc: dial tcp 94.142.143.113:28161: i/o timeout; ecclient: upload failed (node:1jm2eEmECZi5rbTdtmH2vUBxWPZr9sienRpwKZCH8KASRGGP9j, address:5.196.246.191:3051): protocol: expected piece hash; context canceled; EOF; ecclient: upload failed (node:12dn9bfb782GQZ4bQ45v19PHpfbo2aYssYAFD4vVNZWivaGyks3, address:15.235.105.121:28967): protocol: expected piece hash; message timeout; EOF
I’m running the job with the following flags, from a local, copy-compatible storage that I also use to copy up to B2:
-threads 2 -upload-limit-rate 2560 -key /config/duplicacy-priv.pem -key-passphrase xxxxxxxx
This is from the :mini docker container provided by saspus on the latest version available.
Thanks for any insight. This is a repeatable issue as it happened on schedule last night and on demand today during testing.
but I went with Google cloud storage for the time being…
