When using Storj there are 3 options to generate keys:
I’ve used S3 credentials with Storj with no issues in the past
For the “access grant” type it just gives a hex key, without a label.
For the “S3 credentials” type it provides an access key and a secret key.
For the “API Key” type it provides a satellite address and a restricted key.
I’m trying to initialize a storage using the storj:// pattern but the init command prompt asks:
Enter API access key:
Enter the passphrase:
I’ve tried several combinations and it doesn’t work… what am I missing?
Using Duplicacy 3.1.0 (27FF3E).
