I’ve used Duplicacy Web as the primary backup tool for the single volume on my DS920+ for over a year. I’ve defaulted to the “kitchen sink” approach and set up the entire volume as the repository. This appears to collect all of the user files from the shared folders plus other system-related bits and pieces that may or may not be of any use as part of a restore. The backup log is also filled with a lot of noise: “permission denied” and “cannot be opened” entries for system-related files. Here’s the final line from the log today:
WARN BACKUP_SKIPPED 678 directories and 248 files were not included due to access errors
What’s the best way to make the job more “surgical”, ensure that I’m backing up everything that is important (ex: Duplicacy configuration and settings), and keep the logs less noisy?
Sidenote: I currently don’t see a way around using DSM Hyper Backup to grab system configuration details and at least some of the package apps that are installed (of course, HB only backs up “approved” Sysnology packages
). Any alternative suggestions are welcomed.
