I’m trying to backup to S3 which I’ve previously initialised and backed up to several times in the past. However, when I try today, I get the dreaded “The storage has not been initialized” error.
★ Dalek ★ ~ ᐅ duplicacy backup
Storage set to s3://eu-west-1@amazon.com/archive.madra.net/dalek
Checking on S3, I can see that the config file definitely exists:
So, given that lack of config file is the usual reason given for why this error occurs, I’m at a bit of a loss.
To re-iterate, this is a backup which has been set up nearly 2 years ago [as you can see from the creation date on the config file] and used to back up several times before without issue. So it can’t be an initialisation error.
under the post. That of course may include your own post
