Timestamp in logs should be in standardised (ISO) format
Running Duplicacy, then reading the log.
The first line of log shows the timestamp that the backup began. I expect that timestamp to be in the standard ISO8601 format (yyy-mm-dd.
The timestamps in the log is hardcoded to the mm-dd-yyyy format used in America, eg “Beginning backup on 08-09-2026” for 9 August 2026.
It also should not be in the currently-selected system format since that can change over time. Log timestamp formats should be unambiguous and consistent over time.
Where is this “Beginning backup on 08-09-2026” log message coming from? I couldn’t locate it in either the CLI or the GUI.
Apologies, it’s in the backup log, but I think that is generated by Duplicacy Util, not by Duplicacy itself.
I’ll follow up there.
