Hi there. Was hoping to get some help on copying an existing storage repository to a new one. I’m running Duplicacy Web Edition 1.8.1. Command line version is 3.2.3.
The existing storage repository is on OneDrive and scheduled backups have been working just fine. I have four backups being backed up to that repository with daily backups, prunes and checks. With the release of 1.8.1, I noticed the addition of zstd compression and noticed someone else mentioning that they were able to save quite a bit of storage by enabling it, so I decided to follow their lead.
In the Web UI, I paused all backups, prunes and checks to the old repository. Then I set up a copy job from the existing repository to a new one I had created, also on OneDrive, with compression turned on, and ran it. It failed a few times, maybe because it was being throttled by OneDrive, but eventually I seem to have gotten quite close to completion. The last time I tried it, these were the results from the log:
Copy storage OneDrive-fava2 to storage OneDrive-fava2-compressed, status: Failed, log file: copy-20240512-082322.log
Running copy command from /root/.duplicacy-web/repositories/localhost/all
Options: [-log copy -from OneDrive-fava2 -to OneDrive-fava2-compressed]
2024-05-12 08:23:22.394 INFO STORAGE_SET Source storage set to one://Backups/fava2
2024-05-12 08:23:30.163 INFO STORAGE_SET Destination storage set to one://Backups/fava2 - Compressed
2024-05-12 08:30:52.333 INFO SNAPSHOT_COPY Chunks to copy: 2, to skip: 133409, total: 133411
2024-05-12 08:30:53.928 WARN DOWNLOAD_RETRY Failed to decrypt the chunk ba969607fd0de3104dea75d7040b6a26f079becfa8c9d204cc57e07d4ce6cc88: cipher: message authentication failed; retrying
2024-05-12 08:30:54.988 WARN DOWNLOAD_RETRY Failed to decrypt the chunk ba969607fd0de3104dea75d7040b6a26f079becfa8c9d204cc57e07d4ce6cc88: cipher: message authentication failed; retrying
2024-05-12 08:30:56.122 WARN DOWNLOAD_RETRY Failed to decrypt the chunk ba969607fd0de3104dea75d7040b6a26f079becfa8c9d204cc57e07d4ce6cc88: cipher: message authentication failed; retrying
2024-05-12 08:30:56.971 ERROR DOWNLOAD_DECRYPT Failed to decrypt the chunk ba969607fd0de3104dea75d7040b6a26f079becfa8c9d204cc57e07d4ce6cc88: cipher: message authentication failed
When I run a check on the new repository, I get the following:
Running check command from /root/.duplicacy-web/repositories/localhost/all
Options: [-log check -storage OneDrive-fava2-compressed -chunks -tabular -a -tabular]
2024-05-12 10:06:51.641 INFO STORAGE_SET Storage set to one://Backups/fava2 - Compressed
2024-05-12 10:06:58.693 INFO SNAPSHOT_CHECK Listing all chunks
2024-05-12 10:09:56.908 INFO SNAPSHOT_CHECK 0 snapshots and 0 revisions
2024-05-12 10:09:56.911 INFO SNAPSHOT_CHECK Total chunk size is 561,222M in 133409 chunks
2024-05-12 10:09:56.911 INFO SNAPSHOT_VERIFY Verifying 0 chunks
2024-05-12 10:09:56.911 INFO SNAPSHOT_VERIFY All 0 chunks have been successfully verified
I’m running a check on the old repository, but because of its size is taking a while. But so far, everything looks fine. The last check I ran after the last backup to the old repository was also fine.
On the Web UI, the old repository shows as being 761.94G with 4 BackupIDs and 336 revisions. Chunks are 159,205 with 4 revisions. However, for the new repository, it shows 588.48G, 0 Backup IDs with 0 revisions and 133,409 chunks.
At this stage, I’m not quite sure what else to do to successfully copy the old repository to the new so that I can start using the new one. I’m puzzled by the check command shows 0 snapshots and 0 revisions, and why the check command isn’t verifying any chunks. I’m also not sure I know how to address or fix the “Failed to decrypt” messages above. Or why the original repo shows as having 159,205 chunks but the new repo only has a total of 133,411.
Any suggestions or recommendations would be appreciated.
Update: The check on the old repository finished with the following errors at the end:
2024-05-12 21:45:49.684 WARN DOWNLOAD_RETRY Failed to decrypt the chunk acc4fa3ce0605a39bb4bb67bde68c9de23578ccb7de05d818cfc188d4f859282: cipher: message authentication failed; retrying
2024-05-12 21:45:51.083 WARN DOWNLOAD_RETRY Failed to decrypt the chunk acc4fa3ce0605a39bb4bb67bde68c9de23578ccb7de05d818cfc188d4f859282: cipher: message authentication failed; retrying
2024-05-12 21:45:52.492 WARN DOWNLOAD_RETRY Failed to decrypt the chunk acc4fa3ce0605a39bb4bb67bde68c9de23578ccb7de05d818cfc188d4f859282: cipher: message authentication failed; retrying
2024-05-12 21:45:54.204 ERROR DOWNLOAD_DECRYPT Failed to decrypt the chunk acc4fa3ce0605a39bb4bb67bde68c9de23578ccb7de05d818cfc188d4f859282: cipher: message authentication failed
2024-05-12 21:45:54.261 INFO SNAPSHOT_VERIFY Added 38977 chunks to the list of verified chunks
