I’m trying to set up a duplicacy container using saspus’s docker image with tag:mini on my synology NAS: Docker Hub
Attaching the log:
init.sh runing as user root:root(0:0)
Remote available versions… latest: 1.5.0 stable: 1.4.1
Newest cached local version… None
Using version 1.4.1
Downloading executable from https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.4.1
Connecting to acrosync.com (198.199.87.9:443)
wget: error getting response: Connection reset by peer
Download failed
If I SSH into the NAS and run “wget https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.4.1”, it is able to download successfully
I then created a container using saspus’s image with tag:v1.5.0, opening bash terminal in the running container, and ran the command. It also gets the same error
bash-5.1# wget https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.4.1
I googled, and tried various fixes on the v1.5.0 container. After I ran the following command in the v1.5.0 container’s bash terminal, I was able to wget successfully
bash-5.1# apk add ca-certificates wget
fetch https://dl-cdn.alpinelinux.org/alpine/v3.13/main/x86_64/APKINDEX.tar.gz
fetch https://dl-cdn.alpinelinux.org/alpine/v3.13/community/x86_64/APKINDEX.tar.gz
(1/3) Installing libunistring (0.9.10-r0)
(2/3) Installing libidn2 (2.3.0-r0)
(3/3) Installing wget (1.21.1-r1)
Executing busybox-1.32.1-r0.trigger
OK: 15 MiB in 27 packagesbash-5.1# wget https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.4.1
–2021-07-17 11:17:03-- https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.4.1
Resolving acrosync.com (acrosync.com)… 198.199.87.9
Connecting to acrosync.com (acrosync.com)|198.199.87.9|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 31436080 (30M) [application/x-troff-man]
Saving to: ‘duplicacy_web_linux_x64_1.4.1’
duplicacy_web_linux_x6 100%[===========================>] 29.98M 6.02MB/s in 5.8s
2021-07-17 11:17:09 (5.21 MB/s) - ‘duplicacy_web_linux_x64_1.4.1’ saved [31436080/31436080]
After some digging around, I noticed before running “apk add ca-certificates wget”, it is using BusyBox v1.32.1 for wget
Does anyone have any knowledge whether this issue is related to my synology NAS or the docker image? Is there anything I can do to fix it? I’m not too well versed in command lines, but I can understand the basic ones
Any help is greatly appreciated!
