long term duplicacy user here (licensed). been using it for many than 3-4 years IIRC. before the actual question - i’d like to point out that i did try to search the forum extensively before making a new post. the closest threads to my question are Backup vs check stats confusion - #3 by 4degrees and Understanding the -tabular output of the check command, however they don’t answer the below questions.
context: i use duplicacy in a single source (synology NAS), single storage (B2) situation.
first some logs/screenshots:
(a) tail of the output from the most recent backup log:
2022-01-03 09:59:00.667 INFO BACKUP_END Backup for /backuproot at revision 124 completed
2022-01-03 09:59:00.667 INFO BACKUP_STATS Files: 2682641 total, 8530G bytes; 881 new, 15,666M bytes
2022-01-03 09:59:00.667 INFO BACKUP_STATS File chunks: 1865691 total, 8533G bytes; 2922 new, 14,610M bytes, 14,592M bytes uploaded
2022-01-03 09:59:00.667 INFO BACKUP_STATS Metadata chunks: 267 total, 1,349M bytes; 23 new, 178,457K bytes, 56,824K bytes uploaded
2022-01-03 09:59:00.667 INFO BACKUP_STATS All chunks: 1865958 total, 8534G bytes; 2945 new, 14,784M bytes, 14,648M bytes uploaded
2022-01-03 09:59:00.667 INFO BACKUP_STATS Total running time: 00:57:56
(b) json payload sent by backup to the report_url
"computer": "duplicacy",
"directory": "/backuproot",
"end_time": 1641184141,
"new_chunk_size": 15502147584,
"new_chunks": 2945,
"new_file_chunk_size": 15319695360,
"new_file_chunks": 2922,
"new_file_size": 16426991616,
"new_files": 881,
"new_metadata_chunk_size": 182739968,
"new_metadata_chunks": 23,
"result": "Success",
"start_time": 1641180659,
"storage": "thevault",
"storage_url": "b2://somewhere",
"total_chunk_size": 9163312726016,
"total_chunks": 1865958,
"total_file_chunk_size": 9162238984192,
"total_file_chunks": 1865691,
"total_file_size": 9159017758720,
"total_files": 2682641,
"total_metadata_chunk_size": 1414529024,
"total_metadata_chunks": 267,
"uploaded_chunk_size": 15359541248,
"uploaded_file_chunk_size": 15300820992,
"uploaded_metadata_chunk_size": 58187776
(c) the tabular output from the most recent check (after the above backup):
2022-01-03 11:37:25.436 INFO SNAPSHOT_CHECK
thevault | 95 | @ 2021-06-18 21:02 | 2643407 | 7462G | 1073501 | 4949G | 42 | 45,505K | 1073501 | 4949G |
thevault | 98 | @ 2021-07-09 21:02 | 2643903 | 7470G | 1075052 | 4956G | 141 | 683,896K | 1593 | 7,541M |
thevault | 99 | @ 2021-07-16 21:02 | 2645020 | 7503G | 1081510 | 4987G | 26 | 37,809K | 7525 | 38,018M |
thevault | 100 | @ 2021-07-24 10:38 | 2650286 | 7531G | 1086457 | 5010G | 27 | 45,918K | 4981 | 23,698M |
thevault | 103 | @ 2021-08-06 21:02 | 2650140 | 7598G | 1094636 | 5049G | 29 | 36,722K | 8208 | 40,239M |
thevault | 104 | @ 2021-08-13 21:02 | 2650385 | 7609G | 1097046 | 5061G | 7 | 18,806K | 2440 | 12,117M |
thevault | 105 | @ 2021-08-20 21:02 | 2650616 | 7614G | 1098067 | 5066G | 5 | 17,743K | 1028 | 5,021M |
thevault | 106 | @ 2021-08-27 21:02 | 2650799 | 7621G | 1099536 | 5073G | 7 | 17,850K | 1474 | 7,352M |
thevault | 107 | @ 2021-09-03 14:08 | 2672463 | 7804G | 1121735 | 5183G | 2919 | 16,455M | 22302 | 112,397M |
thevault | 109 | @ 2021-09-10 21:02 | 2652984 | 7895G | 1126856 | 5208G | 15 | 59,485K | 8277 | 43,497M |
thevault | 110 | @ 2021-09-17 21:02 | 2653873 | 7923G | 1131641 | 5232G | 16 | 29,868K | 4800 | 24,164M |
thevault | 111 | @ 2021-09-24 21:02 | 2654568 | 7951G | 1135946 | 5253G | 33 | 49,949K | 4343 | 21,340M |
thevault | 112 | @ 2021-10-01 21:02 | 2655123 | 7976G | 1139534 | 5270G | 560 | 870,182K | 4219 | 18,187M |
thevault | 113 | @ 2021-10-08 21:02 | 2655531 | 7991G | 1141551 | 5280G | 483 | 739,608K | 3208 | 14,033M |
thevault | 114 | @ 2021-10-22 21:02 | 2665450 | 8211G | 1166750 | 5402G | 35 | 52,722K | 25100 | 123,148M |
thevault | 115 | @ 2021-10-29 21:02 | 2673457 | 8310G | 1173829 | 5437G | 29 | 50,166K | 7131 | 35,930M |
thevault | 116 | @ 2021-11-05 21:02 | 2674574 | 8392G | 1180754 | 5471G | 608 | 907,362K | 9547 | 45,088M |
thevault | 117 | @ 2021-11-12 21:02 | 2675090 | 8424G | 1186926 | 5501G | 9 | 20,457K | 6782 | 31,525M |
thevault | 118 | @ 2021-11-19 21:02 | 2675658 | 8437G | 1189235 | 5512G | 10 | 33,245K | 2322 | 11,345M |
thevault | 119 | @ 2021-11-26 21:02 | 2676080 | 8451G | 1191442 | 5522G | 11 | 39,101K | 2217 | 10,790M |
thevault | 120 | @ 2021-12-03 21:02 | 2676912 | 8467G | 1194367 | 5536G | 12 | 15,747K | 2940 | 13,898M |
thevault | 121 | @ 2021-12-10 21:02 | 2680029 | 8493G | 1197534 | 5551G | 11 | 17,423K | 3188 | 15,746M |
thevault | 122 | @ 2021-12-17 21:02 | 2680455 | 8504G | 1199585 | 5561G | 9 | 22,628K | 2177 | 10,271M |
thevault | 123 | @ 2021-12-24 21:02 | 2681893 | 8514G | 1201818 | 5572G | 10 | 22,905K | 2243 | 11,019M |
thevault | 124 | @ 2022-01-03 09:03 | 2682641 | 8530G | 1204733 | 5586G | 2945 | 14,648M | 2945 | 14,648M |
thevault | all | | | | 1214491 | 5624G | 1214491 | 5624G | | |
(d) storage size in duplicacy-web:
(e) storage size on backblaze website:
questions:
- For the latest revision (124), the backup log (a) shows new file chunks size as
14,610M bytesand all (file+metadata chunk) size as14,784M bytes, however the check table (c) shows both theuniqandnewchunk size as14,648M. why the difference? - what is the difference between the ‘uniq’ and ‘new’ column sets? how can new chunks for a revision be > uniq chunks to that revision?
- The check table (c) shows the ALL chunk size as
5624Gbut both duplicacy-web (d) and backblaze b2 website (e) show it as 6.04T (6,044.6GB). The only explanation is 6044000000000/1024/1024/1024 = 5628G, which means both duplicacy-web and backblaze are showing TB/GB and logs are showing TiB/GiB… which indeed seems to be the case if you check the json payload (b) and compare it to the backup sizes shown in (a)
