Hey everyone,
I’m facing a very confusing issue with my Unraid appdata backup to OneDrive, and I’m hoping someone here might have some insights.
Background:
For a long time, I’ve been backing up my Unraid’s /mnt/user/appdata directory (approx 550GB) to my OneDrive account. This setup has been working perfectly for ages, staying well within my OneDrive quota.
The Problem:
Yesterday, my OneDrive suddenly reported that it’s completely full. The weirdest part is that the only change I made recently was to modify the include/exclude patterns for the backup.
My Configuration Change:
Previously: My pattern was simply
+appdata/*(meaning everything under appdata was included). -
Recently Changed To:
-appdata/Recycle.Bin/* +appdata/*(I added an exclude pattern to prevent backing up temporary files or deleted items within specific appdata folders, hoping to reduce space).
What I’ve Checked:
- I’ve double-checked the source directory size on my Unraid server (
/mnt/user/appdata), and it’s still around 550GB. Nothing has significantly grown there. - I’ve looked into my OneDrive storage, and it’s indeed showing as full and it is filled by duplicacy directory.
Questions:
- Has anyone experienced something similar when modifying include/exclude patterns, especially when adding an exclusion?
- Could the new pattern have somehow triggered a full re-upload of existing files, creating duplicates or new versions on OneDrive that weren’t being handled before?
- Is there a specific behavior with exclude patterns in certain backup tools (like
rcloneif that’s what’s being used) that I’m unaware of, which could cause this? - What else should I check on either the Unraid side or the OneDrive side?
