Unrecognized public key
I am trying to set up a repository using the new RSA encryption feature
duplicacy init -e -key public.pem repository_id storage_url
The public.pem is a pretty standard
gpg --export --armor key_id > public.pem
Get the message:
unrecognized public key in public.pem
Tried with absolute path and relative paths to key file won’t make a difference.
I am using the pre-build duplicacy_linux_x64_2.3.0
What is my mistake here?:slight_smile:
The key needs to be in the PEM format. It is possible to convert a GPG key to an RSA public key in the PEM format, but I would just generate the keys using the following commands:
openssl genrsa -des -out private.pem 2048
openssl rsa -in private.pem  -pubout -out public.pem
Thank you! The solution was actually in the RSA encryption announcement but I just missed it. Thanks again
I updated the announcement after your question (and @gchen answer) here. :wink:
Thanks for pointing this out.
