We are evaluating vertical backup solution for our ESXi node.
Running check sub-command always fails with the exception of “MemoryError”.
My request to vertical:
time -p ./vertical --print-stack -vv check MariaDB@my-esxi-node -r 1
Output:
Vertical Backup 1.4.0
vm names: ['MariaDB@my-esxi-node'], check all: False, revisions: ['1'], tags: None, verify chunks: False
Attempting to read from environment variable VB_B2_ACCOUNT
Attempting to read b2_account from file '/vmfs/volumes/xxxxxxxxx/_scripts/vertical/.verticalbackup/passwords'
Attempting to read from environment variable VB_B2_KEY
Attempting to read b2_key from file '/vmfs/volumes/xxxxxxxxxx/_scripts/vertical/.verticalbackup/passwords'
Authorization succeeded
Storage set to b2://my-vm-backup
Attempting to read from environment variable VB_PASS
Attempting to read pass from file '/vmfs/volumes/xxxxxxxxxxxxx/_scripts/vertical/.verticalbackup/passwords'
URL request https://f003.backblazeb2.com/file/my-vm-backup/nesting returned status code 404
Chunk read levels: [1], write level: 1
URL request https://f003.backblazeb2.com/file/my-vm-backup/config.vb returned status code 404
Retrieved backup MariaDB@my-esxi-node at revision 1 from the local cache
Downloaded backup MariaDB@my-esxi-node revision 1 tag
Listing all chunks
<type 'exceptions.MemoryError'>
runtime: 73.94 sec
So no stack trace avail, verbose mode did not help either. It simply stops with exception.
Note: I have tried with all VM’s, small ones, big ones, same error each time.
