I’m in New Zealand and I’ve been backing up to Hetzner StorageBox in Germany. Backup speeds were fantastic, with 6-8 threads I was getting 20MB/s. Over 2TB was done within 48 hours.
But testing a restore now, with 12 threads, I’m only able to get 100-200KB/s restoring, this would take me over 200 days to restore my data. I’ve tried the restore with more threads, like 20 and even 50, and it helps a little at 1MB/s but still a very slow speed.
Is there anything that can be done? My latency to Hetzner is about 280ms.
Running in Docker on unRAID.
16GB DDR3
Intel i7 4770
Here’s a restore log with 50 threads for example:
2024-05-06 13:33:24.047 INFO REPOSITORY_SET Repository set to /data/appdata/test
2024-05-06 13:33:24.047 INFO STORAGE_SET Storage set to webdav://HIDDEN@HIDDEN.your-storagebox.de/duplicacy
2024-05-06 13:33:26.096 INFO SNAPSHOT_FILTER Loaded 0 include/exclude pattern(s)
2024-05-06 13:33:26.992 INFO RESTORE_INPLACE Forcing in-place mode with a non-default preference path
2024-05-06 13:33:26.992 INFO RESTORE_INDEXING Indexing /data/appdata/test
2024-05-06 13:33:26.992 INFO SNAPSHOT_FILTER Parsing filter file /cache/localhost/restore/.duplicacy/filters
2024-05-06 13:33:26.992 INFO SNAPSHOT_FILTER Loaded 0 include/exclude pattern(s)
2024-05-06 13:33:27.565 INFO RESTORE_START Restoring /data/appdata/test to revision 2
2024-05-06 13:33:35.583 INFO DOWNLOAD_PROGRESS Downloaded chunk 44 size 1122677, 122KB/s 03:45:24 0.0%
2024-05-06 13:33:45.640 INFO DOWNLOAD_PROGRESS Downloaded chunk 7 size 1255826, 122KB/s 03:44:26 0.1%
2024-05-06 13:33:47.807 INFO DOWNLOAD_PROGRESS Downloaded chunk 8 size 1200791, 166KB/s 02:44:44 0.2%
2024-05-06 13:33:48.162 INFO DOWNLOAD_PROGRESS Downloaded chunk 12 size 1098239, 208KB/s 02:11:58 0.2%
2024-05-06 13:33:48.508 INFO DOWNLOAD_PROGRESS Downloaded chunk 5 size 1235529, 262KB/s 01:44:19 0.3%
2024-05-06 13:33:49.938 INFO DOWNLOAD_PROGRESS Downloaded chunk 22 size 1219062, 303KB/s 01:30:21 0.4%
2024-05-06 13:33:53.825 INFO DOWNLOAD_PROGRESS Downloaded chunk 17 size 1572980, 315KB/s 01:26:49 0.5%
2024-05-06 13:33:54.095 INFO DOWNLOAD_PROGRESS Downloaded chunk 10 size 2253778, 382KB/s 01:11:26 0.6%
2024-05-06 13:33:54.100 INFO DOWNLOAD_PROGRESS Downloaded chunk 6 size 1506690, 435KB/s 01:02:44 0.7%
2024-05-06 13:33:54.194 INFO DOWNLOAD_PROGRESS Downloaded chunk 43 size 2774826, 532KB/s 00:51:14 0.9%
2024-05-06 13:33:55.158 INFO DOWNLOAD_PROGRESS Downloaded chunk 41 size 1293750, 557KB/s 00:48:52 0.9%
2024-05-06 13:33:56.492 INFO DOWNLOAD_PROGRESS Downloaded chunk 32 size 1502912, 587KB/s 00:46:18 1.0%
2024-05-06 13:33:58.769 INFO DOWNLOAD_PROGRESS Downloaded chunk 13 size 1949940, 610KB/s 00:44:31 1.1%
2024-05-06 13:34:01.632 INFO DOWNLOAD_PROGRESS Downloaded chunk 11 size 1854421, 609KB/s 00:44:31 1.2%
2024-05-06 13:34:03.808 INFO DOWNLOAD_PROGRESS Downloaded chunk 39 size 1919762, 627KB/s 00:43:12 1.4%
2024-05-06 13:34:05.808 INFO DOWNLOAD_PROGRESS Downloaded chunk 24 size 2366367, 654KB/s 00:41:21 1.5%
2024-05-06 13:34:06.656 INFO DOWNLOAD_PROGRESS Downloaded chunk 26 size 2284501, 694KB/s 00:38:57 1.6%
2024-05-06 13:34:18.289 INFO DOWNLOAD_PROGRESS Downloaded chunk 40 size 2694186, 584KB/s 00:46:10 1.8%
2024-05-06 13:34:20.884 INFO DOWNLOAD_PROGRESS Downloaded chunk 37 size 3252742, 621KB/s 00:43:20 2.0%
2024-05-06 13:34:21.088 INFO DOWNLOAD_PROGRESS Downloaded chunk 27 size 3187808, 667KB/s 00:40:18 2.2%
2024-05-06 13:34:21.157 INFO DOWNLOAD_PROGRESS Downloaded chunk 9 size 3073585, 721KB/s 00:37:11 2.4%
2024-05-06 13:34:21.917 INFO DOWNLOAD_PROGRESS Downloaded chunk 31 size 2860898, 772KB/s 00:34:41 2.5%
2024-05-06 13:34:25.188 INFO DOWNLOAD_PROGRESS Downloaded chunk 23 size 3500480, 778KB/s 00:34:21 2.7%
