Hi Everyone,
I am new to the software, currently trying to setup backups.
I have installed Duplicacy GUI on a windows server 2012 R2 and I am trying to backup a file share (mapped as network drive) to backblaze.
At first my backup failed because a file was open, I looked it up and the solution is to vss so open files can be backed up.
I then used the -vss option but it failed with error message
ERROR VSS_START Shadow copy creation failed: StartSnapshotSet returned 80042316
In event viewer it shows the following
Volume Shadow Copy Service error: Unexpected error querying for the IVssWriterCallback interface. hr = 0x80070005, Access is denied.
. This is often caused by incorrect security settings in either the writer or requestor process.
Operation:
Gathering Writer Data
I have already enabled file server VSS agent service on the remote file server. On this backup server I am running everything as Admin account.
what am i missing?
thanks for your input.
