Warning (error?) when copying from one storage to another
Hello,
I was wondering what severity is (and/or the implications of) the following message. It appears toward the end of the output when running a “duplicacy copy” command.
Copied chunk 0000000aaaaa ( 1/1049 )
[clip]
Copied chunk 0000000aaaab ( 1049/1049 )
Failed to cache the file snapshots/[snapshot-id]/3: open C:/.duplicacy/cache/[destination-storage-name]/snapshots/[snapshot-id]/3.ariuttft.tmp: The system cannot find the path specified.
Copied snapshot [snapshot-id] at revision 3
Thank you,
Jeremy
This is a bug probably caused by the directory ‘C:/.duplicacy/cache/[destination-storage-name]/snapshots/[snapshot-id]’ was not created beforehand.
However this bug only prevents the snapshot file from being saved in the local cache, so it should not affect the integrity of the backups.
Edit: I was in a hurry and forgot to type ‘not’ twice!
Thank you, that is what I needed to know!
