Hello guys, I have bought the license for my NAS and so far not been able to complete yet a single backup using the web UI.
Always towards the end if I want to check the current backup job I get a 502 Bad Gateway as my reverse proxy can’t access the web UI anymore - checking systemctl --user status duplicacy-web confirms that the service is not active. Looking at duplicacy_web.log it shows hundreds of POST /get_backup_status but I guess thats normal and at the time of the 502:
2025/06/08 21:51:34 Failed to get the value from the keyring: Unable to open dbus session &{%!s(*dbus.Conn=&{0xc00003e560 0xc0004a7080 true ea6a2dce5914a03daf890e6b684605e6 [:1.1] {{0 0} 0 0 {{} 0} {{} 0}} {0 0} 3 map[0:true] map[] {{0 0} 0 0 {{} 0} {{} 0}} 0xc0004a6fc0 0xc00004e180 false {{0 0} 0 0 {{} 0} {{} 0}} 0xc00043e500 <nil> {0 0}}) org.freedesktop.secrets /org/freedesktop/secrets}: The name org.freedesktop.secrets was not provided by any .service files
2025/06/08 21:51:34 Temporary directory set to /tmp/Duplicacy-Repositories
2025/06/08 21:51:34 Schedule Test next run time: 2025-0615 02:00
2025/06/08 21:51:34 Duplicacy Web Edition 1.8.3 (5A554A)
2025/06/08 21:51:35 Duplicacy CLI 3.2.3
But now that I think about it it may be also coming after I restart the service.
Here is the full log of the backup itself:
2025-06-08 12:32:42.150 INFO BACKUP_LIST Listing all chunks
2025-06-08 12:34:59.645 INFO BACKUP_INDEXING Indexing /mnt/nas/PVE_DOCKER
2025-06-08 12:34:59.646 INFO SNAPSHOT_FILTER Parsing filter file /tmp/Duplicacy-Repositories/localhost/2/.duplicacy/filters
2025-06-08 12:34:59.646 INFO SNAPSHOT_FILTER Loaded 4 include/exclude pattern(s)
2025-06-08 13:31:10.130 INFO UPLOAD_KEEPALIVE Skip chunk cache to keep connection alive
2025-06-08 14:01:11.006 INFO UPLOAD_KEEPALIVE Skip chunk cache to keep connection alive
2025-06-08 14:31:12.069 INFO UPLOAD_KEEPALIVE Skip chunk cache to keep connection alive
2025-06-08 15:01:13.168 INFO UPLOAD_KEEPALIVE Skip chunk cache to keep connection alive
2025-06-08 15:31:14.099 INFO UPLOAD_KEEPALIVE Skip chunk cache to keep connection alive
The backup is about 1 TB and it crashed on both a OneDrive backup and a local to local backup.
A backup can complete without Duplicacy service crashing mid-way every time.
See above.
System: Ubuntu Server - Duplicacy as binary file download v3.2.3
Can anyone please help me?
