Run backup from Web UI with global option -comment "LOG_AT_START LOG_VERBOSE"
Expect command to run normally.
Command fails:
Running backup command from /share/CACHEDEV1_DATA/.qpkg/Duplicacy/.duplicacy-web/repositories/localhost/9 to back up /share/Test
Options: [-log -comment "LOG_AT_START LOG_VERBOSE" backup -storage NAS0 -dry-run -stats]
No help topic for 'LOG_VERBOSE"'
Also, exit status is 0, so Web UI shows “Completed” instead of “Failed”
