[Note: everything below that appears critical is meant, sincerely, as constructive criticism. Duplicacy is great and I’m grateful for the work @gchen does to create and improve it. Also I’m grateful for the help many users provide on this forum.]
Before beginning the upgrade (Windows), I looked to the forum to make sure I wouldn’t mess up the upgrade. As expected, I found no clear, complete step-by-step how-to-upgrade description. Instead I found hints and bits of instructions scattered about in various threads. I tried to synthesize these into some instructions for me to follow.
This is what I did:
- I stopped the Duplicacy process in Task Manager.
- The Duplicacy service was no longer running (probably a result of step 1 above), so I couldn’t “stop” it.
- I ran the 1.5.0 install exe as administrator. I chose to install for all users, as I had for previous versions, so Duplicacy would run as a service.
- During the install I got an error message that the service already exists.
- After the install I got the “Duplicacy will store all passwords/credentials in an encrypted form in the configuration file. Please enter a password to encrypt/decrypt these passwords/credentials…” dialog. I thought this was a bad sign because I already had a password from the 1.3.0 install.
- It was a bad sign. When I started 1.5.0 it started from scratch, knowing nothing about my previous 1.3.0 setup.
- After rebooting and rummaging around I find that I have two Web-UI installs. 1.3.0 remains and is still running normally. The new shortcut runs 1.5.0 that remembers nothing about my settings.
Is there a way to recover from this situation, so that I have only one Web-UI, version 1.5.0, that knows all my settings without having to re-enter everything? Also, what step(s) did I miss or get wrong when I just tried to do the upgrade?
