I’m using Duplicacy Web. I’m backing up in Backblaze B2.
check -fossils -resurrect -persist tells me that chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 doesn’t exist but the file chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12.fsl exists in Backblaze B2.
I’m confused. Why is Duplicacy not able to find back the fossil? I’ve deleted the cache locally.
The logs (with debug logs) below. Looking at the logs it seems like Duplicacy is not searching for the fossil. Maybe I’m not providing the correct parameters?
Running check command from /home/lcswillems/.duplicacy-web/repositories/localhost/all
Options: [-log -d check -storage Backblaze -fossils -resurrect -persist -a -tabular]
2025-01-24 23:57:14.509 INFO STORAGE_SET Storage set to b2://lucas-willems-backup-duplicacy
2025-01-24 23:57:14.509 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_BACKBLAZE_B2_ID
2025-01-24 23:57:14.509 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_BACKBLAZE_B2_KEY
2025-01-24 23:57:15.081 INFO BACKBLAZE_URL Download URL is: https://f004.backblazeb2.com
2025-01-24 23:57:15.502 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_BACKBLAZE_PASSWORD
2025-01-24 23:57:16.102 TRACE CONFIG_ITERATIONS Using 16384 iterations for key derivation
2025-01-24 23:57:16.247 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/nesting' returned status code 404
2025-01-24 23:57:16.247 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/nesting did not return headers
2025-01-24 23:57:16.247 DEBUG STORAGE_NESTING Chunk read levels: [1], write level: 1
2025-01-24 23:57:16.251 INFO CONFIG_INFO Compression level: 100
2025-01-24 23:57:16.251 INFO CONFIG_INFO Average chunk size: 4194304
2025-01-24 23:57:16.251 INFO CONFIG_INFO Maximum chunk size: 16777216
2025-01-24 23:57:16.251 INFO CONFIG_INFO Minimum chunk size: 1048576
2025-01-24 23:57:16.251 INFO CONFIG_INFO Chunk seed: bf7cf4031c9b64567018ad56a7769f044c9abbb44119ff9d1d42386c291bb454
2025-01-24 23:57:16.251 TRACE CONFIG_INFO Hash key: 5313f2dbba5c489613e4ce8667302a76dcda5a4826a9b89ec7165361b2d15b90
2025-01-24 23:57:16.251 TRACE CONFIG_INFO ID key: ca989eed2cea76af1a0a45571d31649f5ee22d55d28224457562434f01778d59
2025-01-24 23:57:16.251 TRACE CONFIG_INFO File chunks are encrypted
2025-01-24 23:57:16.251 TRACE CONFIG_INFO Metadata chunks are encrypted
2025-01-24 23:57:16.251 DEBUG LIST_PARAMETERS id: , revisions: [], tag: , showStatistics: false, showTabular: true, checkFiles: false, searchFossils: true, resurrect: true
2025-01-24 23:57:16.251 INFO SNAPSHOT_CHECK Listing all chunks
2025-01-24 23:57:16.251 TRACE LIST_FILES Listing chunks/
2025-01-24 23:57:45.634 TRACE SNAPSHOT_LIST_IDS Listing all snapshot ids
2025-01-24 23:57:45.769 TRACE SNAPSHOT_LIST_REVISIONS Listing revisions for snapshot Data
2025-01-24 23:57:46.319 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/1 from the snapshot cache
2025-01-24 23:57:46.456 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/43 from the snapshot cache
2025-01-24 23:57:46.592 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/149 from the snapshot cache
2025-01-24 23:57:46.726 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/183 from the snapshot cache
2025-01-24 23:57:46.864 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/217 from the snapshot cache
2025-01-24 23:57:47.000 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/238 from the snapshot cache
2025-01-24 23:57:47.135 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/270 from the snapshot cache
2025-01-24 23:57:47.270 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/305 from the snapshot cache
2025-01-24 23:57:47.408 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/340 from the snapshot cache
2025-01-24 23:57:47.545 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/371 from the snapshot cache
2025-01-24 23:57:47.679 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/405 from the snapshot cache
2025-01-24 23:57:47.814 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/427 from the snapshot cache
2025-01-24 23:57:47.951 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/459 from the snapshot cache
2025-01-24 23:57:48.085 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/482 from the snapshot cache
2025-01-24 23:57:48.223 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/483 from the snapshot cache
2025-01-24 23:57:48.358 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/511 from the snapshot cache
2025-01-24 23:57:48.493 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/516 from the snapshot cache
2025-01-24 23:57:48.629 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/517 from the snapshot cache
2025-01-24 23:57:48.764 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/518 from the snapshot cache
2025-01-24 23:57:48.904 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/519 from the snapshot cache
2025-01-24 23:57:49.041 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/520 from the snapshot cache
2025-01-24 23:57:49.177 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/521 from the snapshot cache
2025-01-24 23:57:49.313 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/Data/522 from the snapshot cache
2025-01-24 23:57:49.313 INFO SNAPSHOT_CHECK 1 snapshots and 23 revisions
2025-01-24 23:57:49.314 INFO SNAPSHOT_CHECK Total chunk size is 290,722M in 102266 chunks
2025-01-24 23:57:50.248 DEBUG CHUNK_CACHE Chunk fbbe3db8c109b5a8c4ba8a21fab751878052e00fead303b7ed65f6e19100a605 has been loaded from the snapshot cache
2025-01-24 23:57:50.249 DEBUG CHUNK_CACHE Chunk 3c0374cde46eb1ab3a8a96cd97e51ac1696919ba88382375fe80a83a4ce9af0c has been loaded from the snapshot cache
2025-01-24 23:57:50.251 DEBUG CHUNK_CACHE Chunk a488cef8c003a8382154164a9c72bad0a9b2048070aadb3ca92493bf6e00b087 has been loaded from the snapshot cache
2025-01-24 23:57:50.253 DEBUG CHUNK_CACHE Chunk a9478c126b853304abfb45388e7bfbcf9ccc211186128fa05325cc71b25a0dfe has been loaded from the snapshot cache
2025-01-24 23:57:50.255 DEBUG CHUNK_CACHE Chunk e4dcf6d68f783d94d803ef779cf304f37ac4b2eaad172a955cb45c1022b9bc3a has been loaded from the snapshot cache
2025-01-24 23:57:50.257 DEBUG CHUNK_CACHE Chunk b966845babad85b5267f9610372a7d03e1b3ead1e501de68e8befec0b2e0485c has been loaded from the snapshot cache
2025-01-24 23:57:50.257 DEBUG CHUNK_CACHE Chunk b90aa7c529512812c42b516e6129bdddef34e9ed254f6bad91288c8f8fa290f6 has been loaded from the snapshot cache
2025-01-24 23:57:50.373 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 405 exist
2025-01-24 23:57:50.375 DEBUG CHUNK_CACHE Chunk 222db7a9f763cc84732e1d6c71a41ce3811dc46cea1809b51d9019e7dcbf89a8 has been loaded from the snapshot cache
2025-01-24 23:57:50.376 DEBUG CHUNK_CACHE Chunk 7846a9827e041730e6b4d3d724974056066ec755efd5af66262b0e835a241465 has been loaded from the snapshot cache
2025-01-24 23:57:50.378 DEBUG CHUNK_CACHE Chunk e6a00803e73e8a0bfc4c8a466c90e14c3fd8654edf82353a17bdb8f16f7516b2 has been loaded from the snapshot cache
2025-01-24 23:57:50.378 DEBUG CHUNK_CACHE Chunk b6938e0bb248f37c764446d502024304570fcb66507c8c52bc7b504857a5b811 has been loaded from the snapshot cache
2025-01-24 23:57:50.381 DEBUG CHUNK_CACHE Chunk e18bd225bdc67002f0eafb85a6976bda607314cf85a881868fbcbf768fe93c7e has been loaded from the snapshot cache
2025-01-24 23:57:50.384 DEBUG CHUNK_CACHE Chunk 628e886cf310502663f14e39f0418a2254ed3830b79f8dd5e0fab7f12ae43d20 has been loaded from the snapshot cache
2025-01-24 23:57:50.387 DEBUG CHUNK_CACHE Chunk c311581a719ee1f065716fe041fbe971f16ecbae394ed1fbaaef6de9c4177b88 has been loaded from the snapshot cache
2025-01-24 23:57:50.516 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 427 exist
2025-01-24 23:57:50.517 DEBUG CHUNK_CACHE Chunk 0e3fa289efd518e68dc4f612264459b0badc72598d343e559d87d0bc35480954 has been loaded from the snapshot cache
2025-01-24 23:57:50.518 DEBUG CHUNK_CACHE Chunk 5521dabdff71f550250d7b53059a971e59c21aa47be7d349f61ec90f0c232e77 has been loaded from the snapshot cache
2025-01-24 23:57:50.518 DEBUG CHUNK_CACHE Chunk 57b81624beeefb0fcd1185c75a2a02f7e444fd86f4c2385aaeba067b0fe9c005 has been loaded from the snapshot cache
2025-01-24 23:57:50.521 DEBUG CHUNK_CACHE Chunk ca686765e660cf47f8525d0f3636bba943b30932490f40cb6b642641a3c1384b has been loaded from the snapshot cache
2025-01-24 23:57:50.523 DEBUG CHUNK_CACHE Chunk 9f8f039180fd649d431dee4c22f2c7fb7dd44493ecb93688fa44ba629ad3ca56 has been loaded from the snapshot cache
2025-01-24 23:57:50.527 DEBUG CHUNK_CACHE Chunk fa6313e3acb882a47ecd93861307e0b6a53c41919804c98fe2ec82b2d9965c27 has been loaded from the snapshot cache
2025-01-24 23:57:50.530 DEBUG CHUNK_CACHE Chunk a639a73dbc6d32186a639a00997a62519ac30fa06770f799326684b4e531ba69 has been loaded from the snapshot cache
2025-01-24 23:57:50.534 DEBUG CHUNK_CACHE Chunk 7387bbfcffba87904343be921a04ab320bb630c1c1cee1ce65dd36baa6322f61 has been loaded from the snapshot cache
2025-01-24 23:57:50.534 DEBUG CHUNK_CACHE Chunk 55cbcf7d7e575319982a88d49f0af978d92c83b3cb5e3dfcc9f857c0dde51aa4 has been loaded from the snapshot cache
2025-01-24 23:57:50.682 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 459 exist
2025-01-24 23:57:50.684 DEBUG CHUNK_CACHE Chunk 3f0f8cff4855dadb081b14d9dcde90fae8386018efa8f1b4e63fb3f2ee596620 has been loaded from the snapshot cache
2025-01-24 23:57:50.685 DEBUG CHUNK_CACHE Chunk 32e2c807c1141c45aeed70c2fecef748ac2d62a57d705ede3454c4587e05191f has been loaded from the snapshot cache
2025-01-24 23:57:50.687 DEBUG CHUNK_CACHE Chunk 81399a40ed0168b7c52694312b9a04046b7a4a9b175bbc040e5b4f199b9c7472 has been loaded from the snapshot cache
2025-01-24 23:57:50.692 DEBUG CHUNK_CACHE Chunk 3c94712b4cf4ec9e358f67b74b8dcf3001538de3ecf52450ced6597c6b639598 has been loaded from the snapshot cache
2025-01-24 23:57:50.696 DEBUG CHUNK_CACHE Chunk d002304018279aa170804276aa79402f9d88fa47add790feef28aff5f8cfb8ac has been loaded from the snapshot cache
2025-01-24 23:57:50.698 DEBUG CHUNK_CACHE Chunk 05c1ae18c3fe6cee3784b76c98e34d0b29a73084b86cb250dcfecc1747c76587 has been loaded from the snapshot cache
2025-01-24 23:57:50.702 DEBUG CHUNK_CACHE Chunk ce3046732383cf54ab6316211530b4c8c6fc02697ac125751220e7281b23f9c1 has been loaded from the snapshot cache
2025-01-24 23:57:50.812 INFO SNAPSHOT_CHECK All chunks referenced by snapshot Data at revision 482 exist
2025-01-24 23:57:50.813 DEBUG CHUNK_CACHE Chunk f14029bc5b45cdffebefed4c652dba66d62271502cf48a882d731897c7adf0b9 has been loaded from the snapshot cache
2025-01-24 23:57:50.816 DEBUG CHUNK_CACHE Chunk f9408b85b798e837a131d1209107d9554aba241e7ce474a4fd92bca9728340b8 has been loaded from the snapshot cache
2025-01-24 23:57:50.822 DEBUG CHUNK_CACHE Chunk 5d83c4e1276f517f5e32d9121b34bc9d1dd1d9d4656778afb025535b04c10ee6 has been loaded from the snapshot cache
2025-01-24 23:57:50.827 DEBUG CHUNK_CACHE Chunk 01cab0ba280c067ee72950038d615c47fd081258daab93516f957a31df0886be has been loaded from the snapshot cache
2025-01-24 23:57:50.831 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:50.834 DEBUG CHUNK_CACHE Chunk 6f133527fa04051124c558b81a041fbb89c64b23fe87eac42781e0662486bbec has been loaded from the snapshot cache
2025-01-24 23:57:50.838 DEBUG CHUNK_CACHE Chunk d9ef8e8bb4d87835861608e5bde960612602873a5e7e48097568fffad8ed5c28 has been loaded from the snapshot cache
2025-01-24 23:57:50.841 DEBUG CHUNK_CACHE Chunk 33a1e6b1e0de62ec0f7a31bbf1f66946801fc0cadf48dea188984a6b14e53099 has been loaded from the snapshot cache
2025-01-24 23:57:51.110 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:51.110 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:51.524 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 483 does not exist
2025-01-24 23:57:51.532 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 483 are missing
2025-01-24 23:57:51.533 DEBUG CHUNK_CACHE Chunk 365aeac95601337430ba5d6f1d7175033673f48bfa5a0434b57d36d801545c22 has been loaded from the snapshot cache
2025-01-24 23:57:51.534 DEBUG CHUNK_CACHE Chunk 3ded285e4724cfd28018459d929592f6f9e7a8645b7f513302ed3ba5bbd2e2be has been loaded from the snapshot cache
2025-01-24 23:57:51.536 DEBUG CHUNK_CACHE Chunk a999c25826621a1b207c53174cc259ad0d27094479ebd68029c6923b0f1a469d has been loaded from the snapshot cache
2025-01-24 23:57:51.539 DEBUG CHUNK_CACHE Chunk 3ee2b2f7c912b877d4546f6447edcf3da60cdef95078ecb2092036315579a608 has been loaded from the snapshot cache
2025-01-24 23:57:51.542 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:51.544 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:51.546 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:51.547 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:51.551 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:51.553 DEBUG CHUNK_CACHE Chunk 02de1ce91e4d737a6ca9f264902c4082ac9aec087d02c5063c1080f89ac7923e has been loaded from the snapshot cache
2025-01-24 23:57:51.844 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:51.844 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:51.979 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 511 does not exist
2025-01-24 23:57:51.982 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 511 are missing
2025-01-24 23:57:51.983 DEBUG CHUNK_CACHE Chunk 0cfe60ddf3f4aed2209f1a23532a48d6998b09432d9bd1a2d639b94cce574359 has been loaded from the snapshot cache
2025-01-24 23:57:51.984 DEBUG CHUNK_CACHE Chunk 8cfaf8fe5904dd93edcaa5e806325668d75a7a97d9a05e5a7a930fe4e7094097 has been loaded from the snapshot cache
2025-01-24 23:57:51.985 DEBUG CHUNK_CACHE Chunk 49e44d3ac053e38acd2bb111457b23a4e8e4b5364fc9d1265c9c337df7ab0b51 has been loaded from the snapshot cache
2025-01-24 23:57:51.986 DEBUG CHUNK_CACHE Chunk 31596b3242f135a45830eac3181cf7c62e60cc2a26998f0e9593443039e0624e has been loaded from the snapshot cache
2025-01-24 23:57:51.988 DEBUG CHUNK_CACHE Chunk 9ea9ad9e803bd21d9b379769eac98aa2e61cddbf68c448218431acace92a155d has been loaded from the snapshot cache
2025-01-24 23:57:51.990 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:51.993 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:51.995 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:51.996 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:52.000 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:52.002 DEBUG CHUNK_CACHE Chunk ae98275def9d6e3c7dce5d808ec4ce913379b15c05f991deac1058d6f797e815 has been loaded from the snapshot cache
2025-01-24 23:57:52.296 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:52.296 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:52.430 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 516 does not exist
2025-01-24 23:57:52.441 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 516 are missing
2025-01-24 23:57:52.441 DEBUG CHUNK_CACHE Chunk b6ed1d5c6d70188160c06a7c910a994b0d2e994b096f3029c17da130d371208e has been loaded from the snapshot cache
2025-01-24 23:57:52.443 DEBUG CHUNK_CACHE Chunk 77ddf09a08f171f2d965cec68a7a6f7df65fb00af7a5a2a6d4e297792ca0bad1 has been loaded from the snapshot cache
2025-01-24 23:57:52.445 DEBUG CHUNK_CACHE Chunk 41785ff76714415fe3ca07566402be8de3a8a71891d8414dd7eaa3e588853d1f has been loaded from the snapshot cache
2025-01-24 23:57:52.447 DEBUG CHUNK_CACHE Chunk 92cb6bfe3b18a5562aa7d72f3a581c1a578ba64474b4429ffdd5d3854954f396 has been loaded from the snapshot cache
2025-01-24 23:57:52.449 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:52.451 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:52.455 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:52.456 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:52.459 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:52.461 DEBUG CHUNK_CACHE Chunk 94747636f5d80df4d9aedcccfdb31b08c070c2a160914e5dc0964b8ab2761ae4 has been loaded from the snapshot cache
2025-01-24 23:57:52.753 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:52.753 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:52.888 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 517 does not exist
2025-01-24 23:57:52.893 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 517 are missing
2025-01-24 23:57:52.895 DEBUG CHUNK_CACHE Chunk 73beddd46879245107883849103de30a90594ef12feee370aa3833bed923aadf has been loaded from the snapshot cache
2025-01-24 23:57:52.896 DEBUG CHUNK_CACHE Chunk 633dbb523d901a24f8519114431b2050a85914b82ed755aa2dfa5b0d3a0fc65f has been loaded from the snapshot cache
2025-01-24 23:57:52.896 DEBUG CHUNK_CACHE Chunk 77c42b6625db8caf1d0e682857f83cc6ad39e988a6c4465cb98cacedb1694726 has been loaded from the snapshot cache
2025-01-24 23:57:52.897 DEBUG CHUNK_CACHE Chunk 3a1c117c6843466decd9777dc7602a8b46b3df55438cb995a21f482f38f82b99 has been loaded from the snapshot cache
2025-01-24 23:57:52.898 DEBUG CHUNK_CACHE Chunk aca9349aea57502e7def8fcd275f626787abfc87790df5563f5d031baee0302e has been loaded from the snapshot cache
2025-01-24 23:57:52.901 DEBUG CHUNK_CACHE Chunk 6aced8e1994bc5a8549f6964cbd81e742082dc32ca822bb8ca4a15a5e97f7872 has been loaded from the snapshot cache
2025-01-24 23:57:52.901 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:52.904 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:52.906 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:52.908 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:52.911 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:52.913 DEBUG CHUNK_CACHE Chunk 094f53b42ca63e9430234b36c9d0357c317b36926231c2b384f71a69767db963 has been loaded from the snapshot cache
2025-01-24 23:57:53.204 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:53.204 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:53.339 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 518 does not exist
2025-01-24 23:57:53.341 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 518 are missing
2025-01-24 23:57:53.343 DEBUG CHUNK_CACHE Chunk 98ddec5c6c3d0133708673d55eae52a72d2839295b0a0af42ad8f004858d384b has been loaded from the snapshot cache
2025-01-24 23:57:53.344 DEBUG CHUNK_CACHE Chunk 98d9f11b42ac6f59f0f38ce315ea31e900cd0eb8c8996aa5cc39003bc45b6bac has been loaded from the snapshot cache
2025-01-24 23:57:53.345 DEBUG CHUNK_CACHE Chunk dc387110ca4f5dd1493c934c1ea2d68b8f4ef7d97a88d046f1481d341450f8eb has been loaded from the snapshot cache
2025-01-24 23:57:53.346 DEBUG CHUNK_CACHE Chunk 51281c1bf3a1522873d20c342cc6e357eddef4d5deaffbea45188f7b82d754e5 has been loaded from the snapshot cache
2025-01-24 23:57:53.347 DEBUG CHUNK_CACHE Chunk 61b29d762dbaadf23b9b920998709005760fcda1bc8e61e9b796a8c377587548 has been loaded from the snapshot cache
2025-01-24 23:57:53.348 DEBUG CHUNK_CACHE Chunk 4a591bd2375d5afa4c5bd48fdbb7ff5aab516fa3f44c108309db6bb5093cece1 has been loaded from the snapshot cache
2025-01-24 23:57:53.350 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:53.351 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:53.355 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:53.357 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:53.361 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:53.363 DEBUG CHUNK_CACHE Chunk cd46ff0a3e2e892c2df66320bdfefe8e7e9fe7b8a279fa27547f33137e7a1b78 has been loaded from the snapshot cache
2025-01-24 23:57:53.364 DEBUG CHUNK_CACHE Chunk 1bf3f30bd853036201678fccd042e9d4ddfab6c5bf806b632eaaad8f00b96bea has been loaded from the snapshot cache
2025-01-24 23:57:53.652 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:53.652 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:53.789 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 519 does not exist
2025-01-24 23:57:53.795 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 519 are missing
2025-01-24 23:57:53.795 DEBUG CHUNK_CACHE Chunk 3220efeba78f8849bc64dc291b06c97f20ff660e44f6461ef2b49b67c089db67 has been loaded from the snapshot cache
2025-01-24 23:57:53.797 DEBUG CHUNK_CACHE Chunk 8d246b40b4a02d3f7f5230fc67800eb6f6f8d9eb3e95d0e78116b165df041a40 has been loaded from the snapshot cache
2025-01-24 23:57:53.798 DEBUG CHUNK_CACHE Chunk 485e95f969570f407795b5ea93e2d177fc9c3bcc26502efc6070d2efed0e6a54 has been loaded from the snapshot cache
2025-01-24 23:57:53.800 DEBUG CHUNK_CACHE Chunk 7fa595d29d9a656abb3a08f4e2f2a08906ec97126d92e73b4a31c677dfe9cae5 has been loaded from the snapshot cache
2025-01-24 23:57:53.802 DEBUG CHUNK_CACHE Chunk 7f0ef23029de6b57081cc8e2d85580d6b148d59e1e95215e889a1e44783587d2 has been loaded from the snapshot cache
2025-01-24 23:57:53.804 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:53.807 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:53.811 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:53.813 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:53.816 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:53.818 DEBUG CHUNK_CACHE Chunk 1577b0c6a9cf970977d6af1407db0192c0a94cf1a7c1807774c1fbc6e624048e has been loaded from the snapshot cache
2025-01-24 23:57:54.117 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:54.117 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:54.251 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 520 does not exist
2025-01-24 23:57:54.252 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 520 are missing
2025-01-24 23:57:54.253 DEBUG CHUNK_CACHE Chunk 6f4f015ce3c7657592ad031dcda07754bef5ebc63c1f9fb62c9c4f01e11a0437 has been loaded from the snapshot cache
2025-01-24 23:57:54.255 DEBUG CHUNK_CACHE Chunk c7b1953abf66f80e6d9f6caca683f8ee4f4b18e8265f90c81eeb4be3065a55f0 has been loaded from the snapshot cache
2025-01-24 23:57:54.257 DEBUG CHUNK_CACHE Chunk 664dc9716c5a7a5258d786135137d508197fd0ece8985be45bd0a34a3bd293a3 has been loaded from the snapshot cache
2025-01-24 23:57:54.259 DEBUG CHUNK_CACHE Chunk 9feeb3315f3e0589b3903eb5847440384934ccca3a0ae4b7af57a899837bb287 has been loaded from the snapshot cache
2025-01-24 23:57:54.261 DEBUG CHUNK_CACHE Chunk 26ff1f58f513abc20f09fec887b23bba47e44b6e31b6851ca640057b7e8bb5ee has been loaded from the snapshot cache
2025-01-24 23:57:54.263 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:54.266 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:54.269 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:54.270 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:54.275 DEBUG CHUNK_CACHE Chunk d4880b3c86809f05f1466273e2fc87c4ef23a687bb3a82b6e1b7a35d6e618aa8 has been loaded from the snapshot cache
2025-01-24 23:57:54.277 DEBUG CHUNK_CACHE Chunk 1cb8c89d661fb74aa1bd811a8c115908bd92cb9b7153255ceb1f923b56a6dc0f has been loaded from the snapshot cache
2025-01-24 23:57:54.281 DEBUG CHUNK_CACHE Chunk 8157af1e93e5a3bbebf285a60337452afbeaa914d5a120a4ae835cf0462ea1e5 has been loaded from the snapshot cache
2025-01-24 23:57:54.575 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:54.575 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:54.710 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 521 does not exist
2025-01-24 23:57:54.715 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 521 are missing
2025-01-24 23:57:54.716 DEBUG CHUNK_CACHE Chunk ff8d7d5b4b805993149322992fc54f16c3e83624a934c56f1bae8d0e43843b44 has been loaded from the snapshot cache
2025-01-24 23:57:54.717 DEBUG CHUNK_CACHE Chunk 345eab47a51b6d33dcbd7a58cf6f1252fa5fa4d703d2d5487d19f3cea5affe47 has been loaded from the snapshot cache
2025-01-24 23:57:54.719 DEBUG CHUNK_CACHE Chunk a79fff25b5207aaa88a95ac09e9cca48ed549014e87d69b0efffbd215d2686f4 has been loaded from the snapshot cache
2025-01-24 23:57:54.724 DEBUG CHUNK_CACHE Chunk b6a5ef8ad7d8f988220b0af1f15d11ab15712b913ccce364fdf1e3e95d6ff0e0 has been loaded from the snapshot cache
2025-01-24 23:57:54.727 DEBUG CHUNK_CACHE Chunk fcff65a58204dd726d3b1bcb6aac45ffa70494b62b08345d22597d237c0f3304 has been loaded from the snapshot cache
2025-01-24 23:57:54.730 DEBUG CHUNK_CACHE Chunk da1a8ec26444b98e136b469ddf4cf21069456e567d0d2934316c42b3774483a0 has been loaded from the snapshot cache
2025-01-24 23:57:54.733 DEBUG CHUNK_CACHE Chunk 9520f52d4bcec5ce635e4ef0e32440e4b95a45273c1e20cd4a47ab993bfa8394 has been loaded from the snapshot cache
2025-01-24 23:57:54.734 DEBUG CHUNK_CACHE Chunk 75cd6d376e87b79ce131057e676ab81738c333ad9e7510b1d1be60868c6f0934 has been loaded from the snapshot cache
2025-01-24 23:57:54.738 DEBUG CHUNK_CACHE Chunk adde725080a3b95ec89a6189b5e4221e67ab33a2c285acf5ed1c15a8c01899f2 has been loaded from the snapshot cache
2025-01-24 23:57:54.741 DEBUG CHUNK_CACHE Chunk e50cbaccb030525b85986a9bd8cca71b437a0fa648036ee124c504703b1cf48c has been loaded from the snapshot cache
2025-01-24 23:57:54.745 DEBUG CHUNK_CACHE Chunk e29325ff1dd2608408bd1a552c184ed79c8e944156b0b7b64eef21c89ec6e65a has been loaded from the snapshot cache
2025-01-24 23:57:55.033 TRACE BACKBLAZE_CALL [0] URL request 'HEAD https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12' returned status code 404
2025-01-24 23:57:55.033 DEBUG BACKBLAZE_LIST https://f004.backblazeb2.com/file/lucas-willems-backup-duplicacy/chunks/00/001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 did not return headers
2025-01-24 23:57:55.167 WARN SNAPSHOT_VALIDATE Chunk 00001adfd40d672e6a152250339670625679799bc3a2622ff2e2e1b5c839dc12 referenced by snapshot Data at revision 522 does not exist
2025-01-24 23:57:55.176 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot Data at revision 522 are missing
2025-01-24 23:57:55.176 ERROR SNAPSHOT_CHECK Some chunks referenced by some snapshots do not exist in the storage
