Where is .duplicacy_web folder in the Docker verison
Hello
Sry to bother, trying to create pre and post scripts checking out the tutorials and everyone directs to put them inside the .duplicacy_web folder which for the love of me I can’t find.
I’m using the docker web image
https://hub.docker.com/r/saspus/duplicacy-web
Can someone help me understand where those folders are?
p.s. SSHing into the docker can’t find the folder “~/.duplicacy_web” too
Checking the LOGs and found out where the folder is:
2024/06/12 10:23:54 Failed to read the stat file for storage 'duplicacy-appdata-tmc': open /home/duplicacy/.duplicacy-web/stats/storages/duplicacy-appdata-tmc.stats: no such file or directory
Thanks to this errors, not sure what they are saying, and the .duplicacy-web folder is empty.
Is this expected behavior?
Alrighty, it’s not empty. It’s only empty if I try to mount the folder so I can access it from my system.
The issue is probably the USER that is using those files. Its duplicac:duplicac and I’m mounting it with 1000:1000
heh huh hmm
it’s /config folder in the container, that is exposed as a volume and should be mapped to outside.
https://bitbucket.org/saspus/duplicacy-web-docker-container/src/74d0ce6df329f55dd7682f3e6463301d6e1e81d7/launch.sh#lines-6
But I think you need /cache folder, which replaces ~/.duplicacy_web/repositories:
https://bitbucket.org/saspus/duplicacy-web-docker-container/src/74d0ce6df329f55dd7682f3e6463301d6e1e81d7/launch.sh#lines-15
