Hello friends! New user here and I love how straightforward and effective this software is so far; backups are working fine and the size savings as well as the raw speed of chunk backups are a huge bonus.
However as it says in the title, I’m a bit puzzled as to why I am able to perform file restorations without ever being queried to input the password for a storage-encrypted repository (B2); I’m using the WebUI version and have my master pass set but not saved in any keyfiles so I’m assuming it only exists server side (which is how I want it)
However if anyone should heaven forbid gain access to my master PW, I still don’t want them to be able to manifest any of my data without entering the ‘storage password’ that I set up for my first B2 repo – and yet this is exactly how it functions now, I am never queried for that PW for performing restores.
Is this by design, and if so why? Is this key being stored and called somewhere in my local Duplicacy preferences? If so can I delete this entry somehow to force restores to prompt for the storage password?
Again glad to be here with you all after discovering this powerful tool, and looking forward to any info or suggestions you can give me.
memory should probably not be on top of your concern list
