I am attempting to test this for possible business purpose. In this case, a fast restore would be needed. When I attempt to use Azure cool storage with 4 threads to upload several hundred GB, I am only getting about 4MB/sec.
states that performance should be the same as the hot tier. I got the same performance using 2 threads on dropbox for business.
My network connection can hit 800mb/sec using AZcopy so I know this is not a network issue. Any suggestions here ? I am using the latest web edition for Mac. Would B2 storage be any better? or is this just the general speed of the product?
Duplicacy is not just a copy. It is a scan/read/hash/split/pack/encrypt and then upload. It can only do the latter as fast as the former.
Depending on your source data (i.e., few huge or many small files, SSD, or HDD) disk performance is likely limiting factor. Look at resource monitor when backup is running to see whether it is CPU, memory, or disk queue bound. Often it’s the latter: reading a lot of small files from the rotational media can be very slow, we’re talking kilobytes per second, because of seek latency: the disk spends most of the time moving heads and waiting for the right sector to fly by as opposed to actually transferring data.
Worst offenders are browser caches and other transient files. If you have included them in the backup – exclude. If your dataset legitimately consists of a multitude of small files – then you’ll have to wait it out. Subsequent backups will be faster, because duplicacy would only need to read metadata. This is not specific to duplicacy btw.
Definitely not. It’s one of the fastest in the industry. (I’m a user, not related to the company, so this is not bragging, but praising)
This is fair, but these backups are all coming from RAID or NVME disk is definitely not the issue. Even with those operations I would expect better, our disk speeds are in the order of 5GB/s.
The CLI binary is located under ~/.duplicacy_web/bin/duplicacy_osx_x64_2.7.2
Open the logs of the backup, in the first few lines there would be a path to local cache: e.g. ~/.duplicacy_web/repositories/localhost/0/ or something along those lines. Path to the “repositories” you can look up in WebUI on the settings page.
CD to that directory and call duplicacy binary by full path from above.
e.g.
cd ~/.duplicacy_web/repositories/localhost/0/
~/.duplicacy_web/bin/duplicacy_osx_x64_2.7.2 benchmark [command options]
