I am using Storj with their S3 backend in order to use it with Duplicacy. Just noticed I’ve been having pruning errors. Whole log is pasted below, but relevant part is:
2021-11-08 16:33:26.457 ERROR CHUNK_DELETE Failed to fossilize the chunk f772f468c86968be0e03889aa03a4271ca4ad9ea1754139dedaf0020952a0adf: NotImplemented: A header you provided implies functionality that is not implemented
status code: 501, request id: 16B5AFAF1B30604B, host id:
Options: [-log prune -storage Storj -keep 0:365 -keep 30:180 -keep 7:30 -keep 1:2 -a]
2021-11-08 16:32:22.639 INFO STORAGE_SET Storage set to s3://us1@gateway.us1.storjshare.io/xxxxx
2021-11-08 16:32:23.259 INFO RETENTION_POLICY Keep no snapshots older than 365 days
2021-11-08 16:32:23.259 INFO RETENTION_POLICY Keep 1 snapshot every 30 day(s) if older than 180 day(s)
2021-11-08 16:32:23.259 INFO RETENTION_POLICY Keep 1 snapshot every 7 day(s) if older than 30 day(s)
2021-11-08 16:32:23.259 INFO RETENTION_POLICY Keep 1 snapshot every 1 day(s) if older than 2 day(s)
2021-11-08 16:33:00.185 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 2
2021-11-08 16:33:00.277 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 3
2021-11-08 16:33:00.345 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 4
2021-11-08 16:33:00.418 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 5
2021-11-08 16:33:00.485 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 6
2021-11-08 16:33:00.565 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 7
2021-11-08 16:33:00.634 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 8
2021-11-08 16:33:00.705 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 9
2021-11-08 16:33:00.772 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 10
2021-11-08 16:33:00.843 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 12
2021-11-08 16:33:00.917 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 13
2021-11-08 16:33:00.987 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 14
2021-11-08 16:33:01.055 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 15
2021-11-08 16:33:01.127 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 16
2021-11-08 16:33:01.195 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 17
2021-11-08 16:33:01.264 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 18
2021-11-08 16:33:01.335 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 19
2021-11-08 16:33:01.404 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 20
2021-11-08 16:33:01.474 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 21
2021-11-08 16:33:01.542 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 22
2021-11-08 16:33:01.611 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 24
2021-11-08 16:33:01.682 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 25
2021-11-08 16:33:01.757 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 26
2021-11-08 16:33:01.824 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 27
2021-11-08 16:33:01.893 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 28
2021-11-08 16:33:01.961 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 29
2021-11-08 16:33:02.034 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 30
2021-11-08 16:33:02.100 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 31
2021-11-08 16:33:02.171 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 32
2021-11-08 16:33:02.238 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 33
2021-11-08 16:33:02.308 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 34
2021-11-08 16:33:02.374 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 36
2021-11-08 16:33:02.446 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 37
2021-11-08 16:33:02.512 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 38
2021-11-08 16:33:02.582 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 39
2021-11-08 16:33:02.649 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 40
2021-11-08 16:33:02.721 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 41
2021-11-08 16:33:02.788 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 42
2021-11-08 16:33:02.856 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 43
2021-11-08 16:33:02.927 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 44
2021-11-08 16:33:03.002 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 45
2021-11-08 16:33:03.069 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 46
2021-11-08 16:33:03.138 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 48
2021-11-08 16:33:03.205 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 49
2021-11-08 16:33:03.272 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 50
2021-11-08 16:33:03.341 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 51
2021-11-08 16:33:03.409 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 52
2021-11-08 16:33:03.475 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 53
2021-11-08 16:33:03.544 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 54
2021-11-08 16:33:03.611 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 55
2021-11-08 16:33:03.679 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 56
2021-11-08 16:33:03.746 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 57
2021-11-08 16:33:03.814 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 58
2021-11-08 16:33:03.881 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 60
2021-11-08 16:33:03.949 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 61
2021-11-08 16:33:04.016 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 62
2021-11-08 16:33:04.083 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 63
2021-11-08 16:33:04.151 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 64
2021-11-08 16:33:04.217 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 65
2021-11-08 16:33:04.285 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 66
2021-11-08 16:33:04.352 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 67
2021-11-08 16:33:04.420 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 68
2021-11-08 16:33:04.489 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 69
2021-11-08 16:33:04.564 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 70
2021-11-08 16:33:04.633 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 72
2021-11-08 16:33:04.703 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 73
2021-11-08 16:33:04.770 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 74
2021-11-08 16:33:04.847 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 75
2021-11-08 16:33:04.928 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 76
2021-11-08 16:33:05.000 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 77
2021-11-08 16:33:05.071 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 78
2021-11-08 16:33:05.148 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 79
2021-11-08 16:33:05.217 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 80
2021-11-08 16:33:05.291 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 81
2021-11-08 16:33:05.358 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 82
2021-11-08 16:33:05.425 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 84
2021-11-08 16:33:05.493 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 85
2021-11-08 16:33:05.574 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 86
2021-11-08 16:33:05.648 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 87
2021-11-08 16:33:05.717 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 88
2021-11-08 16:33:05.783 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 89
2021-11-08 16:33:05.852 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 90
2021-11-08 16:33:05.919 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 91
2021-11-08 16:33:05.987 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 92
2021-11-08 16:33:06.054 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 93
2021-11-08 16:33:06.129 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 94
2021-11-08 16:33:06.198 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 96
2021-11-08 16:33:06.267 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 97
2021-11-08 16:33:06.334 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 98
2021-11-08 16:33:06.407 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 99
2021-11-08 16:33:06.476 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 100
2021-11-08 16:33:06.547 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 101
2021-11-08 16:33:06.614 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 102
2021-11-08 16:33:06.683 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 103
2021-11-08 16:33:06.751 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 104
2021-11-08 16:33:06.818 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 105
2021-11-08 16:33:06.886 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 106
2021-11-08 16:33:06.952 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 108
2021-11-08 16:33:07.020 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 109
2021-11-08 16:33:07.087 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 110
2021-11-08 16:33:07.156 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 111
2021-11-08 16:33:07.222 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 112
2021-11-08 16:33:07.294 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 113
2021-11-08 16:33:07.363 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 114
2021-11-08 16:33:07.436 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 115
2021-11-08 16:33:07.505 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 116
2021-11-08 16:33:07.574 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 117
2021-11-08 16:33:07.642 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 118
2021-11-08 16:33:07.711 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 120
2021-11-08 16:33:07.778 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 121
2021-11-08 16:33:07.846 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 122
2021-11-08 16:33:07.943 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 123
2021-11-08 16:33:08.019 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 124
2021-11-08 16:33:08.104 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 125
2021-11-08 16:33:08.178 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 126
2021-11-08 16:33:08.245 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 127
2021-11-08 16:33:08.313 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 128
2021-11-08 16:33:08.380 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 129
2021-11-08 16:33:08.448 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 130
2021-11-08 16:33:08.518 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 132
2021-11-08 16:33:08.587 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 133
2021-11-08 16:33:08.654 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 134
2021-11-08 16:33:08.724 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 135
2021-11-08 16:33:08.791 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 136
2021-11-08 16:33:08.858 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 137
2021-11-08 16:33:08.926 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 138
2021-11-08 16:33:08.996 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 139
2021-11-08 16:33:09.066 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 140
2021-11-08 16:33:09.134 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 141
2021-11-08 16:33:09.201 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 142
2021-11-08 16:33:09.269 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 144
2021-11-08 16:33:09.346 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 145
2021-11-08 16:33:09.415 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 146
2021-11-08 16:33:09.483 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 147
2021-11-08 16:33:09.552 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 148
2021-11-08 16:33:09.619 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 149
2021-11-08 16:33:09.693 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 150
2021-11-08 16:33:09.761 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 151
2021-11-08 16:33:09.831 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 152
2021-11-08 16:33:09.899 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 153
2021-11-08 16:33:09.967 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 154
2021-11-08 16:33:10.034 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 156
2021-11-08 16:33:10.102 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 157
2021-11-08 16:33:10.169 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 158
2021-11-08 16:33:10.237 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 159
2021-11-08 16:33:10.305 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 160
2021-11-08 16:33:10.372 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 161
2021-11-08 16:33:10.443 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 162
2021-11-08 16:33:10.512 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 163
2021-11-08 16:33:10.583 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 164
2021-11-08 16:33:10.650 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 165
2021-11-08 16:33:10.724 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 166
2021-11-08 16:33:10.804 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 168
2021-11-08 16:33:10.871 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 169
2021-11-08 16:33:10.944 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 170
2021-11-08 16:33:11.012 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 171
2021-11-08 16:33:11.079 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 172
2021-11-08 16:33:11.147 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 173
2021-11-08 16:33:11.213 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 174
2021-11-08 16:33:11.283 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 175
2021-11-08 16:33:11.352 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 176
2021-11-08 16:33:11.420 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 177
2021-11-08 16:33:11.487 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 178
2021-11-08 16:33:11.557 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 180
2021-11-08 16:33:11.624 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 181
2021-11-08 16:33:11.695 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 182
2021-11-08 16:33:11.762 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 183
2021-11-08 16:33:11.830 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 184
2021-11-08 16:33:11.897 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 185
2021-11-08 16:33:11.968 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 186
2021-11-08 16:33:12.035 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 187
2021-11-08 16:33:12.103 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 188
2021-11-08 16:33:12.171 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 189
2021-11-08 16:33:12.249 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 190
2021-11-08 16:33:12.323 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 192
2021-11-08 16:33:12.398 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 193
2021-11-08 16:33:12.464 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 194
2021-11-08 16:33:12.531 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 195
2021-11-08 16:33:12.598 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 196
2021-11-08 16:33:12.665 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 197
2021-11-08 16:33:12.732 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 198
2021-11-08 16:33:12.800 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 199
2021-11-08 16:33:12.867 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 200
2021-11-08 16:33:12.935 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 201
2021-11-08 16:33:13.003 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 202
2021-11-08 16:33:13.070 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 204
2021-11-08 16:33:13.136 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 205
2021-11-08 16:33:13.210 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 206
2021-11-08 16:33:13.282 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 207
2021-11-08 16:33:13.351 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 208
2021-11-08 16:33:13.420 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 209
2021-11-08 16:33:13.487 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 210
2021-11-08 16:33:13.556 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 211
2021-11-08 16:33:13.623 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 212
2021-11-08 16:33:13.690 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 213
2021-11-08 16:33:13.758 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 214
2021-11-08 16:33:13.829 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 216
2021-11-08 16:33:13.897 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 217
2021-11-08 16:33:13.964 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 218
2021-11-08 16:33:14.031 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 219
2021-11-08 16:33:14.098 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 220
2021-11-08 16:33:14.165 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 221
2021-11-08 16:33:14.234 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 222
2021-11-08 16:33:14.301 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 223
2021-11-08 16:33:14.369 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 224
2021-11-08 16:33:14.436 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 225
2021-11-08 16:33:14.503 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 226
2021-11-08 16:33:14.570 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 228
2021-11-08 16:33:14.638 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 229
2021-11-08 16:33:14.705 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 230
2021-11-08 16:33:14.773 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 231
2021-11-08 16:33:14.840 INFO SNAPSHOT_DELETE Deleting snapshot shared at revision 232
2021-11-08 16:33:15.324 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 2
2021-11-08 16:33:15.349 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 3
2021-11-08 16:33:15.373 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 4
2021-11-08 16:33:15.398 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 5
2021-11-08 16:33:15.422 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 6
2021-11-08 16:33:15.446 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 7
2021-11-08 16:33:15.470 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 8
2021-11-08 16:33:15.494 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 9
2021-11-08 16:33:15.518 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 10
2021-11-08 16:33:15.543 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 11
2021-11-08 16:33:15.567 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 13
2021-11-08 16:33:15.591 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 14
2021-11-08 16:33:15.615 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 15
2021-11-08 16:33:15.639 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 16
2021-11-08 16:33:15.670 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 17
2021-11-08 16:33:15.697 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 18
2021-11-08 16:33:15.726 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 19
2021-11-08 16:33:15.755 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 20
2021-11-08 16:33:15.780 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 21
2021-11-08 16:33:15.805 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 22
2021-11-08 16:33:15.831 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 23
2021-11-08 16:33:15.855 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 25
2021-11-08 16:33:15.879 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 26
2021-11-08 16:33:15.904 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 27
2021-11-08 16:33:15.928 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 28
2021-11-08 16:33:15.953 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 29
2021-11-08 16:33:15.978 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 30
2021-11-08 16:33:16.009 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 31
2021-11-08 16:33:16.044 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 32
2021-11-08 16:33:16.077 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 33
2021-11-08 16:33:16.104 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 34
2021-11-08 16:33:16.129 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 35
2021-11-08 16:33:16.154 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 37
2021-11-08 16:33:16.178 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 38
2021-11-08 16:33:16.202 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 39
2021-11-08 16:33:16.228 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 40
2021-11-08 16:33:16.252 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 41
2021-11-08 16:33:16.276 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 42
2021-11-08 16:33:16.301 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 43
2021-11-08 16:33:16.325 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 44
2021-11-08 16:33:16.349 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 45
2021-11-08 16:33:16.378 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 46
2021-11-08 16:33:16.402 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 47
2021-11-08 16:33:16.426 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 49
2021-11-08 16:33:16.450 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 50
2021-11-08 16:33:16.475 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 51
2021-11-08 16:33:16.503 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 52
2021-11-08 16:33:16.528 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 53
2021-11-08 16:33:16.552 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 54
2021-11-08 16:33:16.576 INFO SNAPSHOT_DELETE Deleting snapshot docker at revision 55
