Duplicacy docker not backuping when container is restarted
I tried to search this issue but couldn’t find anything about it.
My issue is that if my server / the docker container restarts duplicacy doesn’t backup until I log in at least once in the GUI.
If I log in then it will start the backup’s again.
Is it possible to make it backup without having to log in first? Since now every time I restart my server to update or the docker container gets updated by watchtower it won’t update until I manually log into the web portal.
I am using the saspus/duplicacy-web:latest docker container.
Thanks in advance! Let me know if you need more information.
This is likely because it doesn’t have the encryption password to access the storage. IIRC there is an option to pass that password as an environment variable.
This one: Synology Docker saspus container - keychain & website access
Edit: Linking to the similar topic to cross-reference: Docker Web-UI & Schedule not running
