I want to add an existing B2 bucket, but I get empty Storage page after I add the bucket.
2019/01/02 01:19:58 Running /home/myname/.duplicacy-web/bin/duplicacy_linux_x64_2.1.2 [-log -d info -repository /home/myname/.duplicacy-web/repositories/localhost/all b2://my-backup-bucket]
2019/01/02 01:19:58 Set current working directory to /home/myname/.duplicacy-web/repositories/localhost/all
2019/01/02 01:19:58 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_B2_ID
2019/01/02 01:19:58 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_B2_KEY
2019/01/02 01:20:03 INFO STORAGE_ENCRYPTED The storage is encrypted with a password
2019/01/02 01:20:03 INFO STORAGE_SNAPSHOT ubuntu-backup
2019/01/02 01:20:13 192.168.1.100:55296 POST /lookup_storage
2019/01/02 01:20:14 192.168.1.100:55296 POST /lookup_storage
2019/01/02 01:20:15 192.168.1.100:55296 POST /lookup_storage
2019/01/02 01:20:25 192.168.1.100:55296 POST /add_storage
2019/01/02 01:20:25 Running /home/myname/.duplicacy-web/bin/duplicacy_linux_x64_2.1.2 [-log -d init -e -storage-name ubuntu-backup duplicacy-web b2://my-backup-bucket]
2019/01/02 01:20:25 Set current working directory to /home/myname/.duplicacy-web/repositories/localhost/all
2019/01/02 01:20:25 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_UBUNTU-BACKUP_B2_ID
2019/01/02 01:20:25 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_UBUNTU-BACKUP_B2_KEY
2019/01/02 01:20:27 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_UBUNTU-BACKUP_B2_ID
2019/01/02 01:20:27 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_UBUNTU-BACKUP_B2_KEY
2019/01/02 01:20:27 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_UBUNTU-BACKUP_PASSWORD
2019/01/02 01:20:30 TRACE CONFIG_ITERATIONS Using 16384 iterations for key derivation
2019/01/02 01:20:30 DEBUG BACKBLAZE_CALL URL request 'HEAD https://f001.backblazeb2.com/file/my-backup-bucket/nesting' returned status code 404
2019/01/02 01:20:30 DEBUG BACKBLAZE_LIST b2_download_file_by_name did not return headers
2019/01/02 01:20:30 DEBUG STORAGE_NESTING Chunk read levels: [1], write level: 1
2019/01/02 01:20:30 INFO STORAGE_CONFIGURED The storage 'b2://my-backup-bucket' has already been initialized
2019/01/02 01:20:30 INFO CONFIG_INFO Compression level: 100
2019/01/02 01:20:30 INFO CONFIG_INFO Average chunk size: 4194304
2019/01/02 01:20:30 INFO CONFIG_INFO Maximum chunk size: 16777216
2019/01/02 01:20:30 INFO CONFIG_INFO Minimum chunk size: 1048576
2019/01/02 01:20:30 INFO CONFIG_INFO Chunk seed: 6475706c6963616379
2019/01/02 01:20:30 INFO REPOSITORY_INIT /home/myname/.duplicacy-web/repositories/localhost/all will be backed up to b2://my-backup-bucket with id duplicacy-web
2019/01/02 01:20:32 192.168.1.100:55296 GET /storage
2019/01/02 01:20:32 Failed to read the stat file for storage 'ubuntu-backup': open /home/myname/.duplicacy-web/stats/storages/ubuntu-backup.stats: no such file or directory
2019/01/02 01:20:32 An error has occurred: runtime error: index out of range
2019/01/02 01:20:32 goroutine 63 [running]:
runtime/debug.Stack(0xcc59a1, 0x19, 0xc42016cc58)
/usr/local/go/src/runtime/debug/stack.go:24 +0xa7
main.catchGoroutineError()
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy-web/dwe/dwe_utils.go:26 +0x94
panic(0xbab6e0, 0x11cc620)
/usr/local/go/src/runtime/panic.go:502 +0x229
main.(*Date).Decrement(...)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy-web/dwe/dwe_date.go:141
main.storagesHandler(0xe09820, 0xc420343ce0, 0xc420137200)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy-web/dwe/dwe_storage.go:460 +0x300f
net/http.HandlerFunc.ServeHTTP(0xd7ce90, 0xe09820, 0xc420343ce0, 0xc420137200)
/usr/local/go/src/net/http/server.go:1947 +0x44
net/http.(*ServeMux).ServeHTTP(0x11e01c0, 0xe09820, 0xc420343ce0, 0xc420137200)
/usr/local/go/src/net/http/server.go:2340 +0x130
main.logHTTPRequest.func1(0xe09820, 0xc420343ce0, 0xc420137200)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy-web/dwe/dwe_main.go:542 +0x1c6
net/http.HandlerFunc.ServeHTTP(0xc4201e6220, 0xe09820, 0xc420343ce0, 0xc420137200)
net/http.serverHandler.ServeHTTP(0xc420401930, 0xe09820, 0xc420343ce0, 0xc420137200)
/usr/local/go/src/net/http/server.go:2697 +0xbc
net/http.(*conn).serve(0xc420098d20, 0xe0a1e0, 0xc4203ca440)
/usr/local/go/src/net/http/server.go:1830 +0x651
created by net/http.(*Server).Serve
/usr/local/go/src/net/http/server.go:2798 +0x27b
~/.duplicacy-web/stats/storages is empty.
