I’ve been backing up to Backblaze B2 for over a year now. Suddenly it stopped working. It appears there’s a problem connecting to Backblaze.
Log (I replaced the names and had to break up the URLs b/c the forum only allows 2 links per post):
Running backup command from /home/NAME/.duplicacy-web/repositories/localhost/0 to back up /media/data/Music
Options: [-log backup -storage BACKUPNAME -threads 4 -stats]
2021-04-02 12:00:05.750 INFO REPOSITORY_SET Repository set to /media/data/Music
2021-04-02 12:00:05.750 INFO STORAGE_SET Storage set to b2://BACKUPNAME
2021-04-02 12:00:06.184 INFO BACKBLAZE_URL download URL is: https:// f000.backblazeb2. com
2021-04-02 12:09:18.741 ERROR STORAGE_CONFIG Failed to download the configuration file from the storage: Head https:// f000.backblazeb2. com/file/BACKUPNAME/config: dial tcp 0.0.0.0:443: connect: connection refused
I’m able to ping https://f000.backblazeb2.com just fine from the terminal.
I’m on KDE neon 5.21
