It would help a lot if the forum had a search function. Now people have to search manually or just post a duplicate thread.
You can search via google by adding site:duplicacy.com to your search term.
But see:
and
I’ll switch to Discourse if there is a way to delegate the login to what is being used for duplicacy.com. I know it should be possible. It is just that I don’t have any experience with Ruby so I’ll need some help with that.
So you want SSO login with your existing site as the SSO provider and duplicacy as the client? No problem at all. Look here. You will find more information regarding your specific SSO provider here.
Since you seem to be on the Google Cloud Plattform, this might be useful too: https://support.google.com/a/answer/6087519
Thanks for the pointers. I’ll look into them.
