Does it go through metadata or the files themselves?
I’m asking because I’m setting up a new raid whereas there is both hdd and ssd and I’m keeping the metadata on both.
I wonder if backup using duplicacy will spin up the ssd or not that’s what I want to avoid.
) but by default it looks at the metadata to see if it’s changed (i.e. file size and modification timestamps) and not the contents. If you want it to double-check the contents, you can run it with the
