This is in realated to topic: Cannot re-connect to one drive storage - Support - Duplicacy Forum
I created that topic long time back and there was a solution posted. It worked for a while, but now I am getting same issue very often.
I am using GUI version of duplicacy in an unraid using docker. I have a persistant location for the onedrive token in the docker compose (this was suggested previously)
I have noticed that the duplicacy finds the error very often now:
Running backup command from /cache/localhost/0 to back up /backuproot/arraydata/nextcloud-data
Options: [-log backup -storage OneDrive -threads 1 -stats]
2023-01-06 15:15:49.774 INFO REPOSITORY_SET Repository set to /backuproot/arraydata/nextcloud-data
2023-01-06 15:15:49.774 INFO STORAGE_SET Storage set to one://BACKUPS/Duplicacy
2023-01-06 15:15:49.792 ERROR STORAGE_CREATE Failed to load the OneDrive storage at one://BACKUPS/Duplicacy: invalid character '3' after top-level value
If I create a new storage with the new token it works, but this defeats the purpose of backup as I have to do it almost every other day now. Suprisingly, if I compare token files with notepad++, there is no difference; they are exactly same. In that scenario, I am not sure how and where duplicaly is able to detect invalid character ‘3’, I am guessing it is not in the token itself.
Your guidance will be very helpful. If you need any information please let me know.
Thank you,
