I want to run multiple backups jobs but all into same revision. E.g.
I have sync folder let’s call it cloudrive
I put folder foto1 into clouddrive. Run backup job. Now I put foto1 away and put foto2 inside.
I run backup job again.
Result I have right now are two revision with different data. But I want one revision with both folder.
Is it possible ? Or is possible to somehow flatten / merge revision ?
My problem is, when every revision will have different part of my data I need to remember in which revision are which data.
