I’m constantly getting timeouts when backing up to OneDrive. Do a Check: timeout. Try a Backup: timeout or connection reset by peer. Sometimes it starts working after an hour or two, but today I haven’t been able to get the backup to work at all.
Does anyone else have trouble with OneDrive? The weird thing is that once it starts working, it seems to work fine. One backup took over 3 days. I had to try several times to get it started, but once it was going it worked for the whole 3 days.
Here’s a typical Check failure:
Running check command from /home/dog/.duplicacy-web/repositories/localhost/all
Options: [-log check -storage onedrive-test -a -tabular]
2019-12-12 03:29:32.641 INFO STORAGE_SET Storage set to one://box_backup
2019-12-12 03:30:02.642 ERROR STORAGE_CREATE Failed to load the OneDrive storage at one://box_backup: Get https://api.onedrive.com/v1.0/drive/root:/box_backup?select=id,name,size,folder: dial tcp 13.107.42.12:443: i/o timeout
Here’s a typical Backup failure:
Running backup command from /home/dog/.duplicacy-web/repositories/localhost/2 to back up /media/Pictures
Options: [-log backup -storage onedrive-test -stats]
2019-12-12 15:44:57.036 INFO REPOSITORY_SET Repository set to /media/Pictures
2019-12-12 15:44:57.037 INFO STORAGE_SET Storage set to one://box_backup
2019-12-12 15:45:22.635 INFO BACKUP_START No previous backup found
2019-12-12 15:45:22.635 INFO BACKUP_INDEXING Indexing /media/Pictures
2019-12-12 15:45:22.635 INFO SNAPSHOT_FILTER Parsing filter file /home/dog/.duplicacy-web/repositories/localhost/2/.duplicacy/filters
2019-12-12 15:45:22.635 INFO SNAPSHOT_FILTER Loaded 4 include/exclude pattern(s)
2019-12-12 15:56:50.019 INFO INCOMPLETE_LOAD Incomplete snapshot loaded from /home/dog/.duplicacy-web/repositories/localhost/2/.duplicacy/incomplete
2019-12-12 15:56:50.019 INFO BACKUP_LIST Listing all chunks
2019-12-12 15:57:20.019 INFO ONEDRIVE_RETRY Get https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks:/children?top=1000&select=name,size,folder: dial tcp 13.107.42.12:443: i/o timeout; retry after 344 milliseconds
2019-12-12 16:00:36.591 INFO ONEDRIVE_RETRY Get https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/11:/children?top=1000&select=name,size,folder: read tcp 192.168.22.19:58104->13.107.42.12:443: read: connection reset by peer; retry after 340 milliseconds
2019-12-12 16:06:02.364 INFO ONEDRIVE_RETRY Get https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/fb:/children?top=1000&select=name,size,folder: read tcp 192.168.22.19:58124->13.107.42.12:443: read: connection reset by peer; retry after 838 milliseconds
2019-12-12 16:06:18.396 INFO FILE_SKIP Skipped 6 files from previous incomplete backup
2019-12-12 16:10:20.176 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: http2: stream closed; retry after 291 milliseconds
2019-12-12 16:10:25.349 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: write tcp 192.168.22.19:58156->13.107.42.12:443: write: connection reset by peer; retry after 478 milliseconds
2019-12-12 16:11:56.065 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: stream error: stream ID 1; CANCEL; retry after 3096 milliseconds
2019-12-12 16:14:01.301 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: write tcp 192.168.22.19:58242->13.107.42.12:443: write: connection reset by peer; retry after 4182 milliseconds
2019-12-12 16:15:32.381 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: stream error: stream ID 1; CANCEL; retry after 7691 milliseconds
2019-12-12 16:17:38.080 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: write tcp 192.168.22.19:58258->13.107.42.12:443: write: connection reset by peer; retry after 22741 milliseconds
2019-12-12 16:19:21.626 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: stream error: stream ID 1; CANCEL; retry after 10670 milliseconds
2019-12-12 16:21:19.673 INFO ONEDRIVE_RETRY Put https://api.onedrive.com/v1.0/drive/root:/box_backup/chunks/8e/8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777:/content: stream error: stream ID 1; CANCEL; retry after 51003 milliseconds
2019-12-12 16:22:10.676 ERROR UPLOAD_CHUNK Failed to upload the chunk 8e8bb8b16d6a502b4e4d6fad5e8c5af7e936b60598c6680eadd45b9ab64c4777: Maximum number of retries reached
2019-12-12 16:22:10.916 INFO INCOMPLETE_SAVE Incomplete snapshot saved to /home/dog/.duplicacy-web/repositories/localhost/2/.duplicacy/incomplete
I’m using the Web version on Ubuntu 18.04.3 LTS.
. Next time i do this, please ping me on that. I still stand by my idea though: having a global setting for retries would make things much more user-friendly.
