Thanks for your feedback. I am using an always on computer so only power outages or ISP issues will interfere (which aren’t common but do happen from time to time).
I had reduced down to 4 threads already, so I tried with one thread and it still chokes on the same fossil file. I did double check again it was in the fossils folder. It’s 156 KB and created June 1. I tried running with debug turned on but it didn’t seem to show anything much more. Here are the two lines that proceed the same messages as my first post when I run the debug:
2023-06-10 00:44:43.682 DEBUG CHUNK_CACHE Chunk 43b22a040e2a1205487b4ad9c3eb817d2efcdda5edaf995648f562316c7ff079 has been loaded from the snapshot cache
2023-06-10 00:44:44.620 INFO PRUNE_NEWSNAPSHOT Snapshot JOHNHP2022 revision 4798 was created after collection 1
and then the next message is about the same fossil failing to download.
Edit:
One of my other computers runs a routine check and it is failing there as well:
2023-06-10 10:26:09.354 INFO SNAPSHOT_CHECK All chunks referenced by snapshot JOHN HP2022 at revision 4796 exist
2023-06-10 10:26:09.556 INFO SNAPSHOT_CHECK All chunks referenced by snapshot JOHNHP2022 at revision 4797 exist
2023-06-10 10:26:10.058 WARN DOWNLOAD_FOSSIL Chunk 774c3bd33835d2d37ac7d92450b2b4ad03022f5f9f4ce15e32a076426041baf7 is a fossil
2023-06-10 10:26:10.230 ERROR DOWNLOAD_CHUNK Failed to download the chunk 774c3bd33835d2d37ac7d92450b2b4ad03022f5f9f4ce15e32a076426041baf7: chunks/77/4c3bd33835d2d37ac7d92450b2b4ad03022f5f9f4ce15e32a076426041baf7.fsl does not exist
sigh I just realized the check command referenced above has been running on a schedule daily with resurrect fossils on.
Edit:
I ran the check command with persist. I wonder if I should delete the revision in question and see what happens?
2023-06-10 16:16:03.677 INFO SNAPSHOT_CHECK All chunks referenced by snapshot JOHNHP2022 at revision 4797 exist
2023-06-10 16:16:04.134 WARN DOWNLOAD_FOSSIL Chunk 774c3bd33835d2d37ac7d92450b2b4ad03022f5f9f4ce15e32a076426041baf7 is a fossil
2023-06-10 16:16:04.253 WARN DOWNLOAD_CHUNK Failed to download the chunk 774c3bd33835d2d37ac7d92450b2b4ad03022f5f9f4ce15e32a076426041baf7: chunks/77/4c3bd33835d2d37ac7d92450b2b4ad03022f5f9f4ce15e32a076426041baf7.fsl does not exist
2023-06-10 16:16:04.526 WARN DOWNLOAD_FOSSIL Chunk 168b563b0c41d1ec4d46883a7b0cda03e94a5a053d2699b1937dc55b8f7418b9 is a fossil
2023-06-10 16:16:04.648 WARN DOWNLOAD_CHUNK Failed to download the chunk 168b563b0c41d1ec4d46883a7b0cda03e94a5a053d2699b1937dc55b8f7418b9: chunks/16/8b563b0c41d1ec4d46883a7b0cda03e94a5a053d2699b1937dc55b8f7418b9.fsl does not exist
2023-06-10 16:16:04.898 WARN DOWNLOAD_FOSSIL Chunk 855315d23e0fe1e78b296b034952fdb0dea4b49ce40a764525f49a37ee8007ed is a fossil
2023-06-10 16:16:05.031 WARN DOWNLOAD_CHUNK Failed to download the chunk 855315d23e0fe1e78b296b034952fdb0dea4b49ce40a764525f49a37ee8007ed: chunks/85/5315d23e0fe1e78b296b034952fdb0dea4b49ce40a764525f49a37ee8007ed.fsl does not exist
2023-06-10 16:16:05.292 WARN DOWNLOAD_FOSSIL Chunk c9ba6f1b741b980b513ff17934ad2012fb60e1a4c560d690001472619e28dfda is a fossil
2023-06-10 16:16:05.402 WARN DOWNLOAD_CHUNK Failed to download the chunk c9ba6f1b741b980b513ff17934ad2012fb60e1a4c560d690001472619e28dfda: chunks/c9/ba6f1b741b980b513ff17934ad2012fb60e1a4c560d690001472619e28dfda.fsl does not exist
2023-06-10 16:16:05.409 ERROR SNAPSHOT_CHUNK Failed to load chunks for snapshot JOHNHP2022 at revision 4798: invalid character ‘f’ after top-level value
Failed to load chunks for snapshot FrancesHP2022 at revision 4798: invalid character ‘f’ after top-level value
