For about the last 3 weeks I have been seeing random failures of backup, prune and check jobs using Duplicacy Web-UI. Both manual and scheduled jobs have failed. There doesn’t seem to be a determinable pattern, but the error is always the same:
2020-01-18 03:05:25.686 ERROR STORAGE_CONFIG Failed to download the configuration file from the storage: Head https://f002.backblazeb2.com/bucket name removed/config: x509: certificate signed by unknown authority
Our remote storage are Backblaze B2 buckets. This has happened on multiple buckets as well. It is very random. If a scheduled job fails one time, the next time the schedule runs it usually succeeds. I have had manual jobs fail 2-3 in a row and them work on the 4th time.
Is any one else having this happen? Any thoughts/guidance on diagnosing the issue?
Thanks,
