OK, successfully set up Duplicacy on Computer 1 and backed up files files to a B2 bucket using the Web UI. Then tried to test a restore on Computer 2. When I try to create the B2 storage on Computer 2 (using appropriate Key ID and Application Key), I get asked for the storage password. I realize I don’t have it. (I used Firefox’s suggested strong password when I created the storage in Duplicacy, and perhaps forgot to have Firefox save the password, so the only password I have is the Web UI password.)
How do I fix this?
- I see that the password is stored encrypted in duplicacy.json. Can I recover the storage password in plaintext using the Web UI password?
- I see a
-reset-passwordsoption on thelistcommand (List command details). Can I use this to change the storage password? Do I need the old password to do this? - If recovering or resetting the password isn’t an option, can I clear out the bucket and reinitialize it with a new password?
The last question is probably trivia, because at that point, it’s probably easiest to just delete the bucket and recreate it. Either way I have to do a new data upload, as the old data is unrecoverable.
Let me know if there is anything I haven’t thought of.
