I used gdfs as described in this post. It worked smoothly, and the speed was great, until gdfs reported some abstract errors and some files appeared in “lost_and_found” folder under C:\…\Local\DriveFS
I checked and in the folder were 52 chunks. I noticed that 21 of them were uploaded correctly, but 31 were missing on remote. I decided to leave them as is.
I started new initial backup with changed ID directly to google drive (“gcd://” as storage). It seemed to upload exactly 31 chunks according to the log file.
Then I found some zero size files with .tmp extensions on GDrive remote. I assumed it was partially uploaded chunks. The names of files (before extensions) didn’t have any duplicates anywhere.
I started check -chunks and it ran for half a day and returned this error:
"ERROR DOWNLOAD_CHUNK Failed to download the chunk chunkname: stream error: stream ID 90737; INTERNAL_ERROR; received from peer*
There is no such chunk uploaded on GDrive and or under the lost and found folder.
I restarted the check again and it reported that all chunks were successfully verified.
My questions:
- Does
check -chunkscompare uploaded chunks with the actual corresponding files in repository? Does it use checksum? - Does
checktake into account filters file under .duplicacy folder? - Can I do anything else to be completely sure that the backup is solid?
- Is it necessary?
Thank you gentlemen.
is calculating checksums from chunks, and if this process is deterministic, then BC2 should be the same as BC1. Same chunks, same sizes, everything (even with encryption enabled?). And it should be skipped very quickly.
