Hi - I thought I understood filters, but now I am not sure.
I want to include a separate volume in my main backup of root “/”. I read somewhere here that the way to do it is make a soft link of that volume to root, and it will be included - but it isn’t. I have a link, let’s call it “Drobo”, that links from /Volumes/Drobo to /Drobo. In my include patterns I have put
+Drobo/
It’s now the very first thing in the filters file, it used to be much lower down. I’ve also tried it like
+Drobo/* and some other variants.
It is never included.
Maybe I’m missing something, so I re-read the Filters/Include exclude patterns page here.
I got even more confused by this example:
For instance, the following pattern list doesn’t do what is intended, since the
foodirectory will be excluded so thefoo/barwill never be visited:
+foo/bar/*
Yet above this, it says:
When matching a path against a list of patterns, the path is compared with the part after “+” or “-”, one pattern at a time. Therefore, the order of the patterns is significant. If a match with an include pattern is found, the path is said to be included without further comparisons. If a match with an exclude pattern is found, the path is said to be excluded without further comparison.
So if it truly follows this logic, I am confused.
Say I had a file
foo/bar/bot.txt
If it compares top to bottom as the text says, it would first compare
foo/bar/bot.txt
to the pattern
foo/bar/*
This should match, right? So, accordingly, it stops comparison and never gets to
and it should work as intended.
Now, I suspect that it is more complicated, because I wonder if you’re actually building an in-memory file-tree from the patterns in the file, and doing includes/excludes against the tree, not against the actual list of patterns? If that were the case, then your statement
Makes a lot more sense.
So, now I am wondering, what’s really going on with these, and most importantly, why can’t I get my external volume to be included?
Morgan
