SMB storage input/output error
Hey All,
Installed and started testing out the Web Linux X64 0.2.1 UI.
I’m getting an error when backing up to a network share that is mapped using an SMB:
2018-12-19 11:04:52.060 ERROR UPLOAD_CHUNK Failed to upload the chunk 7307b5f00a68c1fa7a0f0cfb6c32ec4e414010e85d82d0d85885444a47b90967: lstat /media/smb_share_backup/chunks/73: input/output error
2018-12-19 11:04:52.066 INFO INCOMPLETE_SAVE Incomplete snapshot saved to /home/myusername/.duplicacy-web/repositories/localhost/1/.duplicacy/incomplete
The backup was able to start and actually store some files, as I can see them in the shared drive, but its failing almost instantly after indexing. Any help will be greatly appreciated on what to check next.
(I split out this post because this bug isn’t likely caused by the Web GUI).
This input/output error usually means there is some problem with your SMB drive or the network.
That’s fair, the Drive did go offline, but not after some time, I’ll have to get back home and check out what’s going on with it.
