I’ve been using the paid Duplicacy Web Edition for several months without issue, but today I found that one of my three backup jobs has been failing for the last two weeks. The log shows the information below.
I found this bug report referencing something similar, but I’m not using the CLI or local storage (I’m using Dropbox).
I have tried to remove (prune) the problem revision with -id image01 -r 2301 -exclusive but that fails with the same error message (“ERROR SNAPSHOT_CHUNK Failed to load chunks for snapshot image01 at revision 2301…” ). I’ve also tried removing all caches under ~/.duplicacy-web, to no avail.
How can I get this working again?
Running backup command from /home/user/.duplicacy-web/repositories/localhost/1 to back up /media/user/image01
Options: [-log backup -storage Documents -threads 1 -stats]
2023-09-26 21:44:08.023 INFO REPOSITORY_SET Repository set to /media/user/image01
2023-09-26 21:44:08.023 INFO STORAGE_SET Storage set to dropbox://Documents
2023-09-26 21:44:12.996 INFO BACKUP_START Last backup at revision 2301 found
2023-09-26 21:44:13.175 ERROR SNAPSHOT_PARSE Failed to load chunks specified in the snapshot image01 at revision 2301: The chunk hash c68825373047d5bbc05a6<783af100c0dca696eb6f2a37b9d7ef2e75b5e78917 is not a valid hex string
Running duplicacy_web_linux_x64_1.7.2 on Linux Mint 21.2
